timing on a new head gasket
Old Jul 26, 2002 | 09:56 AM
syeve's Avatar
Default timing on a new head gasket
I just switched to a 3mm greddy head gasket...now my car is overheating....is it a timing issue? Should I advance my timing more than before? Its the strangest thing...my car will run perfectly then about twenty minutes into tuning the damn thing overheats? I am confused....never hit more than 12.5 on the lamda, runs a little rich when not boosting but my EGTS are between 8-10 fro normal driving and dont move under boost...I confused
Stock d16
t3 intercooled
dont know what else to include...I'm running 10 PSI with the new head gasket
Vortec FMU (dont think its the fuel though) had it on lambda the whole time...
thanks for you help.
its not coolant, I have filled that thing about 10 times because of alll the overheating (using blead valve every time)
Old Jul 26, 2002 | 10:05 AM
X2BOARD's Avatar
Default Re: timing on a new head gasket (syeve)
Does it take a long time to warm up ? Is the engine bay itself very hot ?
X2
Old Jul 26, 2002 | 10:10 AM
Mikey3000's Avatar
maybe you installed the hg wrong and coolant isn't flowing to the right places.
[Modified by Salvatore Leone, 2:10 PM 7/26/2002]
Old Jul 26, 2002 | 10:16 AM
filetofit
Guest
Posts: n/a
Holy ****, 3mm headgasket, that's almost an eighth of an inch. Hmmm I think a thicker head gasket = more timing advance, have to retard timing to compensate.
3mm divided by 50mm timing gear radius = 0.06 radians or 3.44 degrees timing advance (compared to a zero thickness headgasket, don't know what stock thickness is)
[Modified by filetofit, 7:18 PM 7/26/2002]
Old Jul 26, 2002 | 12:08 PM
syeve's Avatar
Default Re: timing on a new head gasket (Salvatore Leone)
I guess thats possible, I did it myself, and did'nt nitice anything irregular.
the engine bay isnt CRAZY hot...nothing unusual, I havnt drove my car with boost for over 6 months so I ant really remember how hot it use to get...thanks for the tips guys
Old Jul 26, 2002 | 01:47 PM
syeve's Avatar
nebody else?
FearDisH22a4
29
Mar 13, 2014 05:10 PM
pityocamptes
May 4, 2011 08:44 AM
jessevtec
Apr 22, 2005 06:19 PM
eddie1681
Feb 14, 2002 02:30 AM
