best tire pressure for the track?
I have a 00 ek coupe with a b16 and slight mods. What is the best tire pressure to have for the track? I have some 15 ebkei's wrapped with 205/50r15 khumos.
matter the track conditions man....just try out different tire pressure and whatever u feel is the best run it...theres way to many factors just to tell you how much...if ur running street tires like u are its not really gonna make a difference just like doing a burn out on street tires not gonna make a difference
Cool Cool Island Breezes. BOY-EE
1.) That's a pretty vague question. Adding what type of track you're talking about would help. Also, Kumho made more than 1 type of tire. Which kumho?
2.) It's IMPOSSIBLE to answer on the interwebz. It depends on a lot of things. Dial it in yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 EF Hatch »</TD></TR><TR><TD CLASS="quote">I have kumho ecstas. I always heard its better to run on low psi like 10 psi...does that sound right?</TD></TR></TABLE>
IIRC, Kumho makes more than 1 type of ecsta.
You STILL haven't specified what type of track. I'll assume you're going to drag race. You can't safely run 10psi on street radials. I think 10psi may even be a bit low for drag radials. If I'm not mistaken, BFG recommends no lower than 12-15Psi for their DRs.
Your B16A makes 111lb of torque. Do you really think you're going to have traction issues? If the track is prepped, you won't spin much even if you launch from redline.
Go to the track and just figure it out. Run the stock PSI and see what the car does.
