Headlights on warning?
Has anyone done a mod for your car that will alert you when your headlights are on? I've heard that you can get it with a JDM cluster [?]. I was just curious if there was a way to maybe wire a relay to trigger the beeper when your head lights are on and the door is open/key is out. =P
I have decent knowledge with wiring. I installed my own car alarm and read up on relays for fuel kill/ecu kill etc. I have an idea on how to wire it but I'm not entirely sure.
Pin 86 = ignition
Pin 85 = Beeper
Pin 30 = switch side input power
Pin 87a = light side output
That is what I had in mind. When the key is in it won't beep. If the key is out and lights are on the it will beep correct?
Pin 86 = ignition
Pin 85 = Beeper
Re: Headlights on warning? (Mrmatt3465)
what year car 92-95 civic? its realy easy to do
here is a link with the info in it
https://honda-tech.com/zerothread?id=2303449
just go to radio hack get a pezo tweeter from there parts bins there about the size of a quarter and should be no more then $3
Modified by instructor74 at 12:06 PM 9/23/2008
frascati
05-09-2019 08:14 AM
hammerdgolfer
06-11-2007 05:11 PM
TwistedSI
11-08-2003 05:25 PM
