Wheel shaking..
Old Sep 22, 2008 | 05:49 PM
Rick James's Avatar
Default Wheel shaking..
I was changing my breaks the other day and when i went to put the wheel back on i noticed that the wheel was able to move from left to right like if when you havent put on the lug nuts yet... any idea of what it may be??
Old Sep 22, 2008 | 06:48 PM
feeldabazzgsr's Avatar
Default Re: Wheel shaking.. (Rick James)
it happened to my EG and it turned out the outer tie rod end bushing shot..so check your tie rod..ball joint (if there is any leaking) and tight your axle that connects to wheel hub
Old Sep 22, 2008 | 07:19 PM
Rick James's Avatar
Default Re: Wheel shaking.. (feeldabazzgsr)
i tried tightening the bolt that connects to the axel but it was already tight.. i'll check the joints tomorrow...
Old Sep 22, 2008 | 07:51 PM
Thateguhate's Avatar
Isnt this one of the ways to check for bad wheel barrings?? Im not sure myself thats why I ask...
Old Sep 22, 2008 | 07:56 PM
dj_gizmo's Avatar
Default Re: Wheel shaking.. (Thateguhate)
so what is the easiest way to fix a tie-rod if that is the problem because i think i may have the same issue
Old Sep 22, 2008 | 07:59 PM
iluvmyhnda's Avatar
if you have the wheel on and torqued down and you move the wheel left to right and its loose, then its a tie rod. move it top to bottom and its loose then its wheel bearing
Old Sep 22, 2008 | 08:01 PM
Default Re: Wheel shaking.. (iluvmyhnda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyhnda &raquo;</TD></TR><TR><TD CLASS="quote">if you have the wheel on and torqued down and you move the wheel left to right and its loose, then its a tie rod. move it top to bottom and its loose then its wheel bearing</TD></TR></TABLE>
Thanks for clarifying!
Old Sep 22, 2008 | 08:38 PM
Default Re: Wheel shaking.. (dj_gizmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_gizmo &raquo;</TD></TR><TR><TD CLASS="quote">so what is the easiest way to fix a tie-rod if that is the problem because i think i may have the same issue</TD></TR></TABLE>
check this thread out..
https://honda-tech.com/zerothread?id=2333340
Old Sep 24, 2008 | 09:15 AM
dj_gizmo's Avatar
Old Sep 24, 2008 | 10:18 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Not correct. If the wheel moves up and down its a ball joint. A bad wheel bearing will howl when you drive, and you can pull the wheel in and out a little if its really gone, but you'll definately hear it at that point.
Old Sep 25, 2008 | 05:07 PM
Rick James's Avatar
Default Re: Wheel shaking.. (Hondaman56)
ill post a video cause i could move it all ways around but its weird cause the axel, wheel and rotor move but not the caliper...
michael-crxsi
Oct 12, 2010 12:03 AM
soclean1k_JDM
Suspension & Brakes
11
Mar 23, 2010 09:40 PM
90efSI
12
Mar 11, 2007 08:53 PM
Mr. Vapor
Dec 5, 2002 05:29 PM
DavidGSR
Aug 20, 2001 10:53 AM
