head leaking oil?
Old Sep 22, 2008 | 01:57 PM
milkmanLCA's Avatar
Default head leaking oil?
this is an eclipse 4 cyclinder. it seems as if it is leaking oil right under the head and on the block. what do you guys think? or is it dirty?
Old Sep 23, 2008 | 05:50 AM
milkmanLCA's Avatar
Default Re: head leaking oil? (milkmanLCA)
no one?
Old Sep 23, 2008 | 09:26 PM
milkmanLCA's Avatar
not one comment, wow, i thought this was tech
Old Sep 24, 2008 | 12:30 AM
rd91sib18c5r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milkmanLCA &raquo;</TD></TR><TR><TD CLASS="quote">not one comment, wow, i thought this was tech</TD></TR></TABLE>
Honda-tech
Old Sep 25, 2008 | 09:51 AM
whitemic's Avatar
try hondabond on the head or on da valve cover it not prejudice to other cars lol
Old Sep 25, 2008 | 09:56 AM
BrownDx's Avatar
Default Re: head leaking oil? (whitemic)
It's hard to tell from the photo, but maybe you need a valve cover gasket. You may have to post more photos to get a better idea.
Old Sep 25, 2008 | 08:31 PM
milkmanLCA's Avatar
Default Re: head leaking oil? (rd91sib18c5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote">
Honda-tech </TD></TR></TABLE>
your a moron, its still the same stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitemic &raquo;</TD></TR><TR><TD CLASS="quote">try hondabond on the head or on da valve cover it not prejudice to other cars lol</TD></TR></TABLE>
someone else told me that but i wanna do it right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrownDx &raquo;</TD></TR><TR><TD CLASS="quote">It's hard to tell from the photo, but maybe you need a valve cover gasket. You may have to post more photos to get a better idea.</TD></TR></TABLE>
head is clean, leaking begins under, i posted this days ago, im almost certain its a gasket, unless the head is warped or something. it leaks a good amount.
Old Sep 25, 2008 | 09:38 PM
[QUOTE=milkmanLCA]
You should talk, asking about a leaking valve cover get a gasket and some silicon.
Old Oct 3, 2008 | 10:04 PM
milkmanLCA's Avatar
lol you are a moron sir, i asked about a head gasket
head gasket does not equal a valve cover gasket...
Old Oct 4, 2008 | 08:06 AM
King V's Avatar
Blast it clean, then recheck it on exactly where it is. If its the HG, replace. Don't hackjob it and smear Hondabond or Hylomar on it and call it fixed.
Old Oct 4, 2008 | 08:17 AM
milkmanLCA's Avatar
Default Re: head leaking oil? (King V)
yea i agree, motor is coming out tomorrow... its too close to the frame rail to deal with the timing without going crazy... i have the gasket set and other stuff. i dont want to smear honda bond on it. i found some oil in the anti freeze.
Old Oct 4, 2008 | 09:01 AM
Good luck with that POS. Damm eclipse is junk buy a civic.
Old Oct 4, 2008 | 11:52 AM
slomofo's Avatar
GDD Member
I doubt it's the head gasket, it's probably leaking from everywhere else and leaking down in that area. DSMs are notorious for leaking from the valve cover, cam seals, crank seals, oil cooler (oil filter housing), CAS, and oil pressure switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote"> Damm eclipse is junk buy a civic.
I own both and they're both junk.
Old Oct 5, 2008 | 07:55 PM
milkmanLCA's Avatar
Default Re: head leaking oil? (slomofo)
everything is getting new seals, it will be out in the spring, and i agree it is junk, hopefully i can make it nice
RickyBizee
12
Mar 24, 2007 11:48 AM
ted
Mar 18, 2005 08:03 PM
DOHC_EG6
10
Oct 13, 2004 03:52 AM
trooper0641
25
May 11, 2004 04:32 AM
Dammit_Dan_954
Dec 9, 2003 01:56 PM
