1991 Crx Si (B18C GSR) Swap
Old Sep 22, 2008 | 06:59 AM
NRanella's Avatar
Default 1991 Crx Si (B18C GSR) Swap
Hello everyone! I'm in the final stages of the Family's 1991 GSR Crx.
I've run into one problem and would appreciate if anyone could please help me out.
The speedometer cable is mechanical, how do I attach it to the GSR block?
It's kinda important.. haha
I'd appreciate any input; even if its a link to a tutorial on swapping the cluster to something different.
Thank you very much!
-Nicholas
Old Sep 22, 2008 | 07:03 AM
zccr-xsi's Avatar
wire the the elc. vss
one wire for ground
one wire for power
one wire from the vss to the cluster then a wire from the cluster to the ecu.
Old Sep 22, 2008 | 07:05 AM
zccr-xsi's Avatar
https://honda-tech.com/zerothread?id=2321014
Old Sep 22, 2008 | 04:08 PM
Ldo's Avatar
Ldo
Default Re: 1991 Crx Si (B18C GSR) Swap (NRanella)
You have a hydro tranny?
You can get a cable vss from a DA integra and use your existing cluster.
Old Sep 22, 2008 | 04:34 PM
D16SiHatch's Avatar
Default Re: 1991 Crx Si (Ldo)
yep sure can. but having a new cluster is more fun
Old Sep 22, 2008 | 04:36 PM
sleepingciv's Avatar
Default Re: 1991 Crx Si (D16SiHatch)
the d series fit also
and if you decide to run a electric vss all 3 wires go behind the cluster you dont need to run one to the ecu
Old Sep 22, 2008 | 04:45 PM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">yep sure can. but having a new cluster is more fun </TD></TR></TABLE>
yup!
Old Sep 22, 2008 | 06:27 PM
NRanella's Avatar
Thank you all for the help! You're all good people.
I ordered the engine from H-Motors, and they guarantee start-up, and we had two bad injectors and the ignition coil was bad.
So them being a great company worked out a deal of the SiR cluster shipped for $100 bucks!! I'm excited!
I'll post entire build pictures when the care is completely finished, Skunk 2 Mega power exhaust is going to be here tomorrow! I had the local exhaust shop make a Test pipe for me.
Wish me luck.
and thank you all again.
-Nick
jacksonww
May 4, 2009 10:41 PM
street-crx
Mar 7, 2007 05:14 PM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
All_Motor EF9
Jan 4, 2004 05:29 PM
B20zvtecek
Nov 20, 2002 06:30 AM
