crack in water housing
Old Sep 22, 2008 | 03:06 AM
luciffer's Avatar
Default crack in water housing
i have a b16 and i have a crack in the housing that the upper rad hose goes into, where the bleeder screw is. I'm not sure what this part is called? Just wonder if you can buy a new one from honda and what i should be asking them for?
If you can buy a new one, does someone have torque specs for installing it, i couldn't find them in the manual.
Modified by luciffer at 12:13 PM 9/22/2008
Old Sep 22, 2008 | 04:16 AM
sleepingciv's Avatar
Default Re: crack in water housing (luciffer)
search 99 civic si then water pump thermostat
http://www.hondaautomotivepart...(DOHC)
Old Sep 22, 2008 | 05:28 AM
luciffer's Avatar
Default Re: crack in water housing (sleepingciv)
Thanks, I found it on the 94 delsol vtec, but same diagram, number 6. but that diagram shows the bleeder screw and its a different part number. There's no gasket on the diagram either, shouldn't there be a gasket?
any idea on torque specs?
Modified by luciffer at 2:57 PM 9/22/2008
jarret83
Honda Civic (2001 - 2005)
May 29, 2016 02:15 PM
RodWolf19
Jan 26, 2016 02:47 PM
hatchdrvr
Jan 26, 2007 04:08 AM
Silver_Rex
Dec 30, 2004 07:26 PM
Spartanic
Jan 1, 2002 04:46 AM
