15 x 7 +35/41 enkei rpf1 tire size info
Old Sep 21, 2008 | 10:17 PM
CRX831's Avatar
Default 15 x 7 +35/41 enkei rpf1 tire size info
i am planning on getting some enkei rpf1
so i was wondering what would be the proper size tire for the enkei rpf1 15 x 7 + 35
it is going to be mounted on my 1990 honda crx si
or should i consider the 15 x 7 + 41 ?
thanks in advance
Old Sep 22, 2008 | 11:42 AM
TunerN00b's Avatar
Default Re: 15 x 7 +35/41 enkei rpf1 tire size info (CRX831)
Sigh. Just as the title of it says, read the dang FAQ before posting.
Forum Rules and FAQ - READ BEFORE POSTING
https://honda-tech.com/zerothread/1188922
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ &raquo;</TD></TR><TR><TD CLASS="quote">
What size tires should I get?
The proper size depends on your car, not just the wheels you are using. So if you want to ask what size you should get, let us know what kind of car you have (year, model, body style, version)!
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16, 195/45-16
For an Integra or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16, 195/50-16
17" - 205/40/17
Old Sep 22, 2008 | 12:24 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15 x 7 +35/41 enkei rpf1 tire size info (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">15" - 195/50-15</TD></TR></TABLE>
Old Sep 23, 2008 | 08:35 PM
forced00si's Avatar
Default Re: 15 x 7 +35/41 enkei rpf1 tire size info (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Sigh. Just as the title of it says, read the dang FAQ before posting.
you guy's fail.. he is asking about the offset.. not tire size
Old Sep 24, 2008 | 05:18 AM
Cuda's Avatar
^^ uh i think YOU fail... hes asking for TIRE size...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX831 &raquo;</TD></TR><TR><TD CLASS="quote">i am planning on getting some enkei rpf1
thanks in advance</TD></TR></TABLE>
Old Sep 24, 2008 | 06:02 AM
CRX831's Avatar
Default Re: 15 x 7 +35/41 enkei rpf1 tire size info (Cuda)
yea mostly tire size but also which offset whould be better on my car thanks guys
Old Sep 24, 2008 | 06:25 AM
Cuda's Avatar
both would work fine on your car...
if weight is an issue, and i know its not THAT much of a difference, but the +41 are lighter...
Old Sep 24, 2008 | 06:59 AM
CRX831's Avatar
Default Re: (Cuda)
thanks cuda! ill take that info into use!
Old Sep 24, 2008 | 12:59 PM
.:Made in OC:.'s Avatar
Default Re: (CRX831)
+41 +35 on 205/50/15 will fit fine. As long as you are not super slammed, then you shouldnt have a problem rubbing.
Old Sep 24, 2008 | 03:56 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (.:Made in OC:.)
195/50-15 will maintain the accuracy of your speedometer and odometer, and won't reduce your acceleration like the oversized 205/50-15 (which is like putting taller gears on your car).
Old Sep 24, 2008 | 05:30 PM
CRX831's Avatar
Default Re: (nsxtasy)
thanks nsx!
Old Sep 26, 2008 | 07:46 AM
00MRSi's Avatar
Not to thread jack, but anyone have experience with these wheels?
Old Sep 29, 2008 | 04:36 AM
Cuda's Avatar
^^not me personally, but my friends who have think its one of the best wheels out there bang for buck...
fairly cheap, strong, lightweight wheel... thats why this is my next set
Old Sep 29, 2008 | 09:10 AM
00MRSi's Avatar
Default Re: (Cuda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuda &raquo;</TD></TR><TR><TD CLASS="quote">^^not me personally, but my friends who have think its one of the best wheels out there bang for buck...
fairly cheap, strong, lightweight wheel... thats why this is my next set </TD></TR></TABLE>
ok. thanks.
Old Oct 1, 2008 | 04:58 AM
Furyof4's Avatar
Default Re: (00MRSi)
These are the best bang-for-the-buck wheels out right now. Ive had a set for 3yrs now and have put them through alot. lots of autox's, track days, 10k+ street miles no problems whatsoever. The finish on these wheels also resists brake dust and chipping very well.
I would get the +41 offset. With 41's and 205 azenis, f+r had to be rolled a little. +35 offset would make it harder to fit any wide 195's or 205.
Modified by Furyof4 at 5:23 PM 10/1/2008
wreckonize
Apr 16, 2009 03:12 PM
BradyGSTYLE
Feb 2, 2009 06:52 PM
c-r-x
Mar 19, 2008 01:48 PM
near495
Nov 30, 2007 05:52 AM
EGII
May 1, 2007 04:13 PM
