Rear Disk Conversion
Old Jul 26, 2002 | 08:24 AM
sekone's Avatar
Default Rear Disk Conversion
i have a 97 cx hatch...no ***** yet (B18 swap on the horizon) and wanted to have four wheel disk brakes on the whip...i was just curious if anyone has had this done to their car or has any helpful tips, suggestions, etc....thanks
-seek
Old Jul 26, 2002 | 08:37 AM
CheezeFrog's Avatar
Default Re: Rear Disk Conversion (sekone)
I got my rear discs off a '94 Integra LS. Took the whole trailing arm assembly from the Integra actually. But I only used the rear discs. All you really need to do is swap trailing arm assemblies if you have the entire trailing arm. But you'll probably need a re-alignment afterwards. My swap was a little more difficult because I didn't use the trailing arms from the Integra, so I had to unbolt the discs from the Teg trailing arms, then swap them with my drum assemblies. Parking brake cable wasn't too bad... it's all very logical.
One thing though -- I think the parking brake cables are a little shorter on an Integra. So I had to adjust the parking brake "load leveler" thing so that it would reach the ends of the parking brake cables.
Old Jul 26, 2002 | 09:10 AM
sekone's Avatar
thanks man...have you ever heard of anyone using the Si rear set up? they do have "rear wheel disks" don't they?
Old Jul 26, 2002 | 09:12 AM
Jackson's Avatar
Why not swap the fronts out as well? The rears only do 20% of the braking. Your civic brakes are 9.5" in diameter and the integra ones are 10.3", just get front and rear. Everything bolts up. While you are at it, you will want to get the si proportioning valve to give the right amount of braking to your newly acquired rear discs and get a 98+ integra master cylinder and booster.
Old Jul 26, 2002 | 09:20 AM
EKB18BPR3's Avatar
Default Re: Rear Disk Conversion (Jackson)
what donor is the easiest disc swap to my 93 vx?
Old Jul 26, 2002 | 09:21 AM
sekone's Avatar
thanks for the info jackson...i had planned on swaping both front and back i was actually just curious how hard it would be and if there was anything "special" i needed or had to do....but from what you said, should be easy peasey, japanesey thanks a lot bro
Mr.Hatch's Avatar
The rear disks on my 99 DX came off of a 93 Si. And you don't HAVE to get a new master cylinder or proportioning valve.
Old Jul 26, 2002 | 09:32 AM
sekone's Avatar
Default Re: Rear Disk Conversion (Mr.Hatch)
i'll keep that in mind also mr. hatch....thanks
Old Jul 26, 2002 | 09:35 AM
Looose_R's Avatar
its not as important to get the prop valve unless your switching to type brakes all the way around
Old Jul 26, 2002 | 09:39 AM
Kalokohan's Avatar
New User
Default Re: Rear Disk Conversion (dniedacess)
Rear disks from either an SI or EX from the same generation.
Old Jul 26, 2002 | 10:12 AM
Jackson's Avatar
You dont have to, but if you want your rear brakes to lock up before your fronts, then so be it.
[Modified by Jackson, 11:12 AM 7/26/2002]
Old Jul 26, 2002 | 11:18 AM
Mr.Hatch's Avatar
Yeah that's why i said it like i did. It's one of those "you don't need to but it's recommended" type of things.
[Modified by Mr.Hatch, 2:19 PM 7/26/2002]
slo_hatch
Apr 23, 2008 06:08 AM
mnichols
Aug 22, 2006 06:59 PM
EsCo_EsCo
Oct 10, 2005 07:54 PM
MugenHonda
Jun 12, 2003 05:14 PM
