B18C EJ1 coversion
Hey guys
i just did my B18c conversion in my EJ1 civic coupe, im running a full integra engine and loom , also running a OBD2A ecu using a harness OBD1-OBD2A ,starts up fine , just wondering is there anything extra wiring or need to do anything to the harness , ie , knock sensor,etc, .
If so can someone please step me through adding or slicing these wires
Any help would be much apprciated,
I did the same swap in my eg coupe and i didnt wire the knock sensor or second butter flies on the manifold
I had ordered an ecu from phearable.net and it comes with thoughs deletes and my car runs great
Just a suggestion on what you might want to do so you dont have to run new wires from your ecu
j_scobar
Mar 6, 2008 10:56 AM
eg6hatch
Jun 22, 2003 09:45 AM
