h22 in a 1990 honda civic wagon?
Old Sep 21, 2008 | 03:11 PM
LLCjr's Avatar
Default h22 in a 1990 honda civic wagon?
Can a h22 drop right in a honda civic wagon like a b series? if not what is the modification i would have to do to install it? need you guys help.... thanks
Old Sep 21, 2008 | 06:39 PM
likwid2u's Avatar
Default Re: h22 in a 1990 honda civic wagon? (LLCjr)
mounts shifter box, shifter cables, axles ecu
Old Sep 22, 2008 | 05:31 AM
gearhead16's Avatar
Default Re: h22 in a 1990 honda civic wagon? (likwid2u)
an h is alot harder than a b series u need more parts and time
Old Sep 22, 2008 | 07:35 AM
LLCjr's Avatar
Default Re: h22 in a 1990 honda civic wagon? (gearhead16)
What parts do I need besides the basic parts such as mounts, transmission,axles..etc
Old Sep 22, 2008 | 07:58 AM
efjones9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likwid2u &raquo;</TD></TR><TR><TD CLASS="quote">mounts shifter box, shifter cables, axles ecu</TD></TR></TABLE>
Old Sep 22, 2008 | 07:00 PM
likwid2u's Avatar
thats basicallly it...... where at in ontario do you live?
Old Sep 23, 2008 | 10:56 AM
LLCjr's Avatar
Off the 60 and archibald
Old Sep 23, 2008 | 11:51 PM
likwid2u's Avatar
so you live close to me......whats your wagon look like?
Old Sep 24, 2008 | 06:57 AM
LLCjr's Avatar
Brown with a red pin stripe on the molding a oem bra dropped on wheels
Old Sep 24, 2008 | 06:21 PM
likwid2u's Avatar
any pics of it?
Old Sep 24, 2008 | 06:47 PM
LLCjr's Avatar
Do u have a wagon or something
Old Sep 24, 2008 | 07:44 PM
jdmallmotorhatch's Avatar
theres a lot of work that goes into doing a straight h22.. i think a H2B would be easier and would probably cost the same but take less time for install... check out the Hybrid forum here!!
Old Sep 24, 2008 | 07:49 PM
likwid2u's Avatar
no but you probably seen a wagon that i did work on driving around archibald...... its blue with a red pinstripe
Old Sep 24, 2008 | 07:50 PM
likwid2u's Avatar
Default Re: (jdmallmotorhatch)
h2b would be allot easier than h22 only
Old Sep 24, 2008 | 09:54 PM
LLCjr's Avatar
Default Re: (likwid2u)
Ok do it have a roof rack on it and you live my mountain view skool like u live at the end of walnut at the corner house
Old Sep 25, 2008 | 12:24 AM
likwid2u's Avatar
Default Re: (LLCjr)
yup!
likwid2u's Avatar
Default Re: (LLCjr)
i get told where i live allot
Old Sep 25, 2008 | 08:33 AM
LLCjr's Avatar
Oh u seen me b4 im pretty sure I pass by there all the time I live like 5 min away from there
Old Sep 25, 2008 | 12:11 PM
RA61825's Avatar
Default Re: (LLCjr)
i think i seen your car , i got to chaffey and im always in the streets
Old Sep 25, 2008 | 12:19 PM
shaggyeg6si's Avatar
The straight h22 swap isn't difficult, and doesn't require you to notch your frame. Custom axles are still needed. Expect to spend days on wiring. Good luck!
Old Sep 25, 2008 | 01:29 PM
LLCjr's Avatar
I was reading on the h2b swap I like it but its so much work u have 2 do 2 even install that 2 buy the qsd kit I heard that cost about 1600 plus shaving pulleys and all that...idk about that 1 either....i wanted 2 be different and do something like that cuz I wana try something different from a b series
Modified by nsxtasy at 5:32 PM 9/25/2008
Old Sep 25, 2008 | 02:48 PM
likwid2u's Avatar
Default Re: (LLCjr)
did you buy your car from deandre? the h2b kit is way worth it though,
Old Sep 25, 2008 | 03:21 PM
It's worth the fact that you dont have to run shifter cables, and can retain a shifter rod assembly. And a larger selection of optimal trans'. I still suggest using the H trans.
Old Sep 25, 2008 | 04:03 PM
LLCjr's Avatar
yes bought it from dee and all i did so far to it was change the wheels on it to jdm black racings and upgraded the shocks and i added oem jdm honda window visor and added oem jdm honda speaker pods in the rear and i got a yakima roof rack to that ima put on...thats about it...but neways do you have a fender roller need to roll my fenders asap
Old Sep 25, 2008 | 04:04 PM
LLCjr's Avatar
Default Re: (shaggyeg6si)
and i might go h2b i wanna be diff so maybe it will b in the works
