1994 Integra Ls won't start
Old Sep 21, 2008 | 11:31 AM
ocbls21's Avatar
TRIAL USER
Default 1994 Integra Ls won't start
I have a 94 Integra ls it is pretty much stock expect for intake, exhaust, and stereo and it will not start. The distributor fried and i replaced it, the fuel pump is good, and the ecu is good. I also replaced the plugs and wires. I tried spraying starter fluid in to the intake manifold and nothing happened. I can here the fuelpump turn on and I can hear the starter click too. There is really no spark. I'm stumped and can anybody give me some advice on whats wrong?
Modified by ocbls21 at 2:39 PM 9/21/2008
Modified by ocbls21 at 7:21 PM 9/22/2008
Old Sep 21, 2008 | 11:51 AM
dc4-b20's Avatar
check grounds.
is the starter clicking?
Old Sep 21, 2008 | 12:36 PM
(FTK)_DE_Tangler's Avatar
Default Re: 1994 Integra Ls won't start (ocbls21)
i had that same problem for a bit, i had to replace my battery and my starter, and even tho i did all that i still kinda have to step on the clutch funny sometime to her to crank.
Old Sep 21, 2008 | 12:41 PM
steveharrmr23's Avatar
Default Re: (dc4-b20)
check your coil it might be poop does it make any kinda noise when you try to start it like pops and such out the exhaust
Old Sep 21, 2008 | 02:11 PM
ocbls21's Avatar
TRIAL USER
the starter is good it clicks when i try to start it, and it does not make a popping noise out of the exhaust
Old Sep 21, 2008 | 03:06 PM
jxnguyen's Avatar
check the fuel pump fuse under your dash. i had the same problem as you and i couldnt find the fuse so i just started to pull out a bunch of fuses and i finally found it.
Old Sep 22, 2008 | 09:18 AM
ocbls21's Avatar
TRIAL USER
Default Re: 1994 Integra Ls won't start (jxnguyen)
i can hear my fuel pump turn on. should i still check that fuse under the dash?
mattbeezy
Apr 30, 2010 06:41 PM
kgreenhaw
Nov 21, 2009 05:03 PM
eskerley
Apr 21, 2008 08:01 PM
austindoyle2506
Sep 16, 2007 08:58 AM
jackedup99lude
Apr 22, 2005 10:11 AM
