Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Rough shift into 3rd gear....AUTOMATIC V6 '03
Old Sep 21, 2008 | 10:11 AM
creator1322's Avatar
Default Rough shift into 3rd gear....AUTOMATIC V6 '03
When my car shifts into 3rd, it does a slight rev up and than shifts into 3rd. Fluid level is good and fluid has been changed in last 15,000.
I don't want to make any assumptions, but are there any diagnosis thoughts.
Old Sep 21, 2008 | 12:10 PM
kroze's Avatar
Default Re: Rough shift into 3rd gear....AUTOMATIC V6 '03 (creator1322)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creator1322 &raquo;</TD></TR><TR><TD CLASS="quote">When my car shifts into 3rd, it does a slight rev up and than shifts into 3rd. Fluid level is good and fluid has been changed in last 15,000.
I don't want to make any assumptions, but are there any diagnosis thoughts.</TD></TR></TABLE>
lol transmission is going.
Old Sep 21, 2008 | 01:23 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Rough shift into 3rd gear....AUTOMATIC V6 '03 (kroze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze &raquo;</TD></TR><TR><TD CLASS="quote">
lol transmission is going. </TD></TR></TABLE>
Get on the phone with American Honda. They might help you pay for it.
Old Sep 22, 2008 | 04:09 AM
YeuEmMaiMai's Avatar
dispite what ANYONE here tells you, the 03-07 accords have the SAME POS 5AT used in the 01-03 Acura CL/TL type S. it's toast and needs to be replaced because your 3rd gear clutch pack is toast...........
do it quick before you get the dreaded limp home mode where the car downshifts into 2nd and stays there........and this really sucks when you are doing 65-70 on the fwy when it happnes
Old Sep 22, 2008 | 07:10 AM
Default Re: Rough shift into 3rd gear....AUTOMATIC V6 '03 (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">dispite what ANYONE here tells you, the 03-07 accords have the SAME POS 5AT used in the 01-03 Acura CL/TL type S. it's toast and needs to be replaced because your 3rd gear clutch pack is toast...........
do it quick before you get the dreaded limp home mode where the car downshifts into 2nd and stays there........and this really sucks when you are doing 65-70 on the fwy when it happnes</TD></TR></TABLE>
Any idea what the fix is and how much it costs?
Do they replace the whole transmission or just 3rd....mainly though how much is this repair?
Thanks!
Old Sep 22, 2008 | 03:48 PM
kroze's Avatar
You'll need new transmission which cost a couple grand & cost of labor to remove the old & install the new.
Old Sep 27, 2008 | 07:45 AM
that trans will run about $4K from the dealer installed. Takes about a week. Call HOA after you have the dealer diag it see if they will good will a replacement for you or help pay for some of the cost
Old Sep 27, 2008 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">that trans will run about $4K from the dealer installed. Takes about a week. Call HOA after you have the dealer diag it see if they will good will a replacement for you or help pay for some of the cost</TD></TR></TABLE>
i'll try it out. But i think i have too many miles...127,000.
jaysome01
Sep 19, 2008 11:53 AM
Flux
Dec 4, 2006 07:25 PM
TopNotchR
Sep 24, 2004 06:50 PM
Cyphear
Jun 20, 2004 03:51 PM
ooooitswilson
18
Sep 15, 2003 02:09 PM
