gsr throttle body on typeR intake manifold
Old Sep 21, 2008 | 10:01 AM
t-splice.mn's Avatar
Default gsr throttle body on typeR intake manifold
wonderinf if this will work or do i need to get a diff. throttle body to fit a usdm type r intake manifold? thanks
Old Sep 21, 2008 | 10:36 AM
EFsSuck's Avatar
Default Re: gsr throttle body on typeR intake manifold (t-splice.mn)
it will bolt up perfectly
Old Sep 21, 2008 | 03:36 PM
excellent, thank you
Old Sep 21, 2008 | 06:53 PM
jomama's Avatar
the real question is why would you do this? the diameters are different, which i assume you know. also, the cables you'll be using will be different lengths unless you rig something up. hopefully this is just a temporary fix. GL.
Old Sep 21, 2008 | 07:29 PM
i do not know this, thats why i'm asking about it. basically what i am doing is putting a usdm type r head w/ intake manifold on my gsr block. i am wondering if i need to buy a different throttle body for reasons like jomama (lol) mentioned. any other concerns i should have? oh, its going in a 2000 gsr body, so i would think the cable would work fine unless the typer intake manifold is completely different size.
Old Sep 22, 2008 | 12:40 PM
IN VTEC's Avatar
Default Re: (t-splice.mn)
Everything is compatible except for the throttle pulley, which will determine which throttle cable and bracket(s) you will use.
You can do it one of two ways:
1.) Swap the throttle pulley on the GS-R TB for a B16 or ITR one. The problem with this is that the throttle pulleys are only sold with the throttle bodies. If you want one, you'll have to cannabalize it off another throttle body.
2.) Use the GS-R throttle pulley and buy the GS-R throttle cable and throttle cable bracket if it's not already on there.
Old Sep 22, 2008 | 05:40 PM
Default Re: (IN VTEC)
i guess i'm not quite following you here.... i have a gsr tb with all gsr cables and stuff, stock gsr setup on my gsr. are you saying that i can just use that stuff and hook it up to a typer tb? or can i just hook the whole gsr tb up to the new manifold, or is that a bad idea because the diameters are diff?
Old Sep 22, 2008 | 06:53 PM
IN VTEC's Avatar
The difference in diameters is okay. As long as the throttle body is smaller than the inlet on the manifold.
Remove the pulley, spring, and bracket from the GS-R throttle body, and install it on the ITR TB.
Old Sep 22, 2008 | 07:37 PM
ok, i think igot what you are saying, see if the gsr tb works and if not get a type r tb or equivelent and use my gsr cables.... right?
Old Sep 29, 2008 | 10:48 AM
del-slo-sd's Avatar
What you are trying to do will work fine. The only problem you might have is the throttle cable might hit against the hood of the car because the type r intake manifold has the throttle body higher up than the gsr manifold. If the cable does hit the hood, then you would need to buy an ITR throttle cable, throttle cable bracket, and put a non gsr pulley on your gsr throttle body. (the gsr is setup to pull the throttle from above, whereas the type r throttle pulls straight horizontally.) this gets rid of that bracket that sticks up above the throttle body on the gsr, and moves it away from the hood.
if the cable does not hit, then you will be fine using the stock gsr, TB, bracket, and cable.
i have the gsr motor in my del sol, and the cable hits the hood with a type r style intake manifold. you may not have this problem in an integra though.
Old Sep 29, 2008 | 08:05 PM
awesome, thank you for your input del slo
Old Nov 8, 2008 | 10:11 AM
ku's Avatar
ku
will b18b ls tb fit on skunk2 im version 1
with type r tb cable bracket?
nabin
Texas -OK -LA (Sales)
May 7, 2010 12:43 AM
eg customs
14
Nov 29, 2008 07:10 AM
BOOSTED_JDM_DB8
Apr 13, 2006 02:42 PM
