Can you paint over single stage urethane?
Old Sep 21, 2008 | 09:57 AM
Eyger's Avatar
Default Can you paint over single stage urethane?
I'm going to paint the interior door panels again... first time I did it, I sanded the plastic, sprayed an epoxy primer, sanded, then a single stage acrylic urethane.
Question is,
can I just sand the single stage, then lay urethane base coat and clear on top?
Or do I have to sand the single stage, put more primer, then base coat and clear coat?
Old Sep 21, 2008 | 10:19 AM
jasoncrashtech's Avatar
Default Re: Can you paint over single stage urethane? (Eyger)
if i tried to, i would seal it first. you can't remove it ?
Old Sep 22, 2008 | 09:47 PM
Eyger's Avatar
Yeah I mean, I can sand it off. I was just curious if I had to or not, or if adhesion would be a problem if I painted right overtop of the SIngle stage urethane.
Old Sep 23, 2008 | 03:18 AM
IMPATIENT's Avatar
Default Re: (Eyger)
itll be fine if you prep it well, bulldog it and seal it. knocking it down and priming it wouldnt be a bad idea either.
EatSleepJDM
Paint and Body
24
Apr 7, 2009 06:42 AM
Sic_DA_Nine
Paint and Body
Nov 22, 2008 06:49 AM
Eg2Love
Paint and Body
10
Sep 20, 2008 06:20 PM
SuicideSlide
Paint and Body
35
Jul 2, 2008 03:14 PM
downeyballz
Paint and Body
Jan 26, 2008 09:06 AM
