ctr pistons for ls vtec. need help
Old Sep 21, 2008 | 09:12 AM
rjc89sir's Avatar
Default ctr pistons for ls vtec. need help
interested in stepping up my compression ratio for my ls vtec. i know im probably gonna have to use race fuel, but my concern is clearance issues. i have a b16 head with skunk stage 2 cams. is there going to be any clearance issues or can this be done succesfully? any info. will help. thanks
Old Sep 21, 2008 | 04:23 PM
killerpenguin21's Avatar
Default Re: ctr pistons for ls vtec. need help (rjc89sir)
there are much better ways to up your compression, ie deck the head..or for that matter much safer and more effective piston choices.
what are you currently using?
Old Sep 21, 2008 | 04:30 PM
rjc89sir's Avatar
Default Re: ctr pistons for ls vtec. need help (killerpenguin21)
all i want to know is if there is enough clearance to use the ctr pistons on a ls/vtec application. i know there are safer pistons out there. i have itr pistons right now, but i want to use ctr pistons and race fuel to make more power on the dyno.
Old Sep 21, 2008 | 04:42 PM
then youll have to clay the motor.
no one will be able to tell you if the clearances that your motor has will be enough.
Old Sep 22, 2008 | 12:12 PM
N2HIFI's Avatar
i ran pct / ctr pistons in my ls/vtec
used a A1 block and b16 head with a oem gasket and stage 1 SK2's i had no clearance issues .. granted thats not the same as your stage 2's but it's what little info i can offer
Old Oct 5, 2008 | 10:37 AM
chanDAman562's Avatar
Default Re: ctr pistons for ls vtec. need help (N2HIFI)
i have the exact same setup.... you wont have any probs with clearance! get it tuned and game over!!!! good setup!
Old Oct 6, 2008 | 02:14 PM
Frenshawas's Avatar
wish i had the same luck. i had the b1 block with ctr pistons and a type r head on blox cams. i cranked it drove it to the stop sign cut the signal on to make a right. boom. while sitting still..................
Old Oct 6, 2008 | 02:52 PM
DonF's Avatar
Default Re: ctr pistons for ls vtec. need help (chanDAman562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chanDAman562 &raquo;</TD></TR><TR><TD CLASS="quote">i have the exact same setup.... you wont have any probs with clearance! get it tuned and game over!!!! good setup!</TD></TR></TABLE> Good deal, you have someone to give you a warranty, and cover any loses/
Old Oct 6, 2008 | 03:20 PM
omniman's Avatar
Default Re: ctr pistons for ls vtec. need help (DonF)
I think what i find most ignorant is the fact that the dome runs parallel to the valve face and posses no change in clearance. Its just an extension of an existing angle. The minor difference in compression height has no real significant change in valve to piston clearance on a stock unmilled head.
The next interesting fact is that the CTR piston is about 8-10% heavier than the ITR piston. Im sure the rod bolts will love that.
Spoons aren't responsible for obesity.
i found this post in the forced induction forum funny too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voodoo on 23s &raquo;</TD></TR><TR><TD CLASS="quote">i have 440s and a 255 walbro. now isnt the chip like a base map just like a hondata or crome would start with and then why couldnt i just fine tune it with a afc. and what difference is street tuning with wide band and dyno tuning with a wide band besides seeing the hp output? sorry if im being difficult all this and im sitting on s200 in my garage just dont wanna pay for the boost option and dyno tune right now. and blowing the motor is fine cuz im building one.</TD></TR></TABLE> thats so wasteful, next thing you know this guy will be burning 100 dollar bills for fun.
Old Oct 6, 2008 | 03:42 PM
slofu's Avatar
Default Re: ctr pistons for ls vtec. need help (omniman)
Perhaps the 'on 23s' part of his SN refers to his brain cell count
Old Oct 6, 2008 | 03:45 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman &raquo;</TD></TR><TR><TD CLASS="quote"> I think what i find most ignorant is the fact that the dome runs parallel to the valve face and posses no change in clearance. Its just an extension of an existing angle. The minor difference in compression height has no real significant change in valve to piston clearance on a stock unmilled head.
thats so wasteful, next thing you know this guy will be burning 100 dollar bills for fun. </TD></TR></TABLE> But Steve, he has chanDAman562iving giving him a warranty if anything goes wrong. He says it's OK and is backing up his claim. I think.
Old Oct 6, 2008 | 04:36 PM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> But Steve, he has chanDAman562iving giving him a warranty if anything goes wrong. He says it's OK and is backing up his claim. I think.</TD></TR></TABLE>
Yeap, that's 99% of the problem. Most of these people with the ctr piston ls-vtec don't have them for more than a year.
en00be
Dec 7, 2008 04:40 PM
oneslodx
25
Apr 4, 2008 04:44 AM
bOOsT-FeIn
Oct 30, 2006 07:55 PM
ID_ten_T
Jun 15, 2003 04:14 PM
-Racer X-
Apr 8, 2002 06:16 PM
