Brakes Failing ftl
coming off the parkway (nj). Wheel clyinder and whole drum assembly = garbage.
i know drums are a pain but what about wheel cylinders? hard? easy? never done them before.
they are just as easy. get new ones, remove old ones. replace and bleed. but if i were you, i would use it as an excuse to spend the money for a disc conversion
look for stuff from junkyards. 90-00 integra.
just a reminder, its a good idea to replace the trailing arm bushings with new ones. on civics, 92-00 trailing arm bushings are 28 bucks and you can find the part number from myhondaparts.com
if you find 94-00 integra trailing arms, the $28 bushing fits no problem (and a vice and a hammer will get them out and it just fine. i didnt need the bushing press that the DIY says you need)
90-93 intergra bushings are 75 bucks BUT you can use the guts from the 90-93 trailing arm on your civic one. (i know cause i had to do this for my 95 civic cause a bolt was froze and snapped on the teg trailing arm).
any questions, pm me and i will answer em.
look for stuff from junkyards. 90-00 integra. just a reminder, its a good idea to replace the trailing arm bushings with new ones. on civics, 92-00 trailing arm bushings are 28 bucks and you can find the part number from myhondaparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">they are just as easy. get new ones, remove old ones. replace and bleed. but if i were you, i would use it as an excuse to spend the money for a disc conversion
any questions, pm me and i will answer em.</TD></TR></TABLE>
lol i totally would but my cars beat up as ****. i just use it to get around to work ect. hopefully in the future ill be able to do that but for now, im sol.
Thanks for the help man
HondanoobIe
Aug 10, 2011 02:05 PM
mingbling96
May 21, 2005 07:54 AM
