loud vibration noise
the car is a 91 si with b16 swap
ok im having a hard time finding out where the noise is coming from. it sound like its coming from the axels area. but im not sure. its not the wheel bearing. the noise only happen when the engine has a load.
i have to do this tomrow or when it stop raining in seattle, from what i can tell there is nothing rubbing. i replace the axel to be safe and nothing changed.
What you dont like all the rain lol
The rubbing will be a thin line on the cv shaft. if not that recheck wheel bearings with the car in the air and spin the tires all of them. look for loose bolts. look at your exhaust for rubbing marks
Make sure the lug nuts are properly set, and not cross threaded.
Had a similar issue from a car, and it only makes the rattling noise when moving and with a load.
My definition of load is when the car is moving.
If not, that, good luck. try what the other guy is saying, it all helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 »</TD></TR><TR><TD CLASS="quote">the car is a 91 si with b16 swap
ok im having a hard time finding out where the noise is coming from. it sound like its coming from the axels area. but im not sure. its not the wheel bearing. the noise only happen when the engine has a load. </TD></TR></TABLE>
Check all motor mounts
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic »</TD></TR><TR><TD CLASS="quote">
Check all motor mounts</TD></TR></TABLE>
Did you cut/grind the mount off of the front cross member?
i checked all the mounts and there perfectly fine. when i was looking under the car i look at the passenger side axle and it seem that its not setting all the way in the hub. you think thats the problem? remember i took out all the dust seal. i been doing some research and some people said that the 89 teg axle would kind fix the problem because there a little shorter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 »</TD></TR><TR><TD CLASS="quote">i checked all the mounts and there perfectly fine. when i was looking under the car i look at the passenger side axle and it seem that its not setting all the way in the hub. you think thats the problem? remember i took out all the dust seal. i been doing some research and some people said that the 89 teg axle would kind fix the problem because there a little shorter. </TD></TR></TABLE>
Thats were i feel i am getting all my problems from, the passenger side axle. I dont think a straight 89 teg axle will work?
I wonder if this is just an Si problem because i have lots of buddies with Ef's and for the passeneger side axle they all use the 90-93 integra axle and have no problems???
Check this out
http://www.hasport.com/news/ar...2.htm
Check this out
pcorad
22
Sep 1, 2014 09:23 AM
highkiwi
Sep 28, 2010 04:25 PM
slowslow
Apr 22, 2009 08:37 PM
scott1ct
Jun 11, 2007 05:43 PM
