LSVTEC no crank on start and no fuel pressure>>>>>>>>pls help
Old Sep 20, 2008 | 04:43 PM
SDP190416's Avatar
Default LSVTEC no crank on start and no fuel pressure>>>>>>>>pls help
LSVTEC B18B1/ B16 P/P HEAD, IHE, VAFC, MSD 6A, chip P28 ecu.
drove my car home and everything was working fine. I tried starting it the next day, i wasnt getting no crank on the starter and i notice i dont have any fuel press on my my gauge. i also noticed when my car is turned to the on position, the oil press and battery lamp stays on and its dim.
Troubleshooting: checked the starter in accordance with the honda dealership manual and my starter works fine, it spins and the gear pops out when i applied 12v on the starter, my fuel pump is the same way. i checked all the fuses and none of them were burnt or popped, i changed the engine harness and power cable from the batt to the starter, i checked all my harnesses on my ecu and everything looks normal. i also check the main and starter relay. i did a test on the main relay and the plug connecter and it checks good. i also checked the starter relay, i was supposed to get a continuity when i applied 12v on B,D plug and i can hear it click, but im not getting any continuity.
i really need some help, i am tired of chasing wires. thanks
Old Sep 20, 2008 | 07:47 PM
twinksack's Avatar
* B A N N E D *
Default Re: LSVTEC no crank on start and no fuel pressure>>>>>>>>pls help (SDP190416
check the battery
Old Sep 21, 2008 | 10:14 AM
SDP190416's Avatar
i have 12v straight from the battery.
Old Sep 21, 2008 | 10:45 AM
deftonerider's Avatar
how about while cranking test the voltage as it cranks
99 SI TYPE R
Mar 11, 2014 05:44 AM
vietnamezerice
Jan 21, 2009 10:23 PM
SDP190416
Sep 22, 2008 12:39 AM
FSS13foxtrot
Apr 1, 2008 08:05 PM
SJR
Jan 28, 2005 12:50 PM
