Clutch adjustment problem
I have a 91 honda crx and i just replaced the clutch but the clutch lever has inches of free play and the clutch adjuster will tighten all the way before any feel in the pedal. i replaced the clutch because of this problem and checked the cable for stretching but it doesnt help and ive run out of ideas. some help would be greatly appreciated!
I did. i replaced the whole clutch assembly. is there any way the clutch lever could rotate on its connecting rod? is that possible? i looked at my other crx and the lever is pointing down when adjusted while my current car's clutch lever is pointed slightly up.
