Butterfly wiring
Old Sep 20, 2008 | 10:24 AM
suichgo's Avatar
Default Butterfly wiring
I've a eg with a gsr swap. I was going to hook up the butterfly but can't seem to find the pink/blue (goes to A17) wire on the gsr harness. There is a red wire but I found two. One on the little connector with two wires and the main harness. So which do I use? A20 where it should go has a plug in it already, so do I remove this or leave it?
thanks
Old Sep 20, 2008 | 11:15 AM
vtecb18c's Avatar
Default Re: Butterfly wiring (suichgo)
its plugged in but where is the other end plugged into if it is?
Old Sep 20, 2008 | 11:45 AM
suichgo's Avatar
Default Re: Butterfly wiring (vtecb18c)
they hook up to the ECU harness
Old Sep 20, 2008 | 11:46 AM
vtecb18c's Avatar
thats what im saying...their plugged into the ecu harness so where are the other ends? are they plugges in or just hangin there?
Old Sep 20, 2008 | 12:37 PM
suichgo's Avatar
I'm hooking them up to the gsr harness. the wires are seperate wires.
Old Sep 20, 2008 | 12:43 PM
vtecb18c's Avatar
ok so get a haynes manual from your local auto parts store for an integra GSR and find out where the wires go
rick_rabies
Jun 30, 2009 12:01 PM
Carolina Fried Rice
16
May 2, 2007 06:28 PM
RTW DC2R
Dec 31, 2004 04:58 PM
gezer
Aug 28, 2004 11:33 PM
krshultz
Oct 27, 2002 05:52 PM
