painting my jdm thin sidmoldings... HOW?
Old Sep 19, 2008 | 03:27 PM
teh Dirka's Avatar
Default painting my jdm thin sidmoldings... HOW?
i just got some jdm thin side moldings and wanted to paint them, but they are really textured... does that mean if i want to have them painted, that i would have to sand them down hella to make it smooth? or will the paint stick to it with some epoxy primer? thanks guys!
Old Sep 19, 2008 | 04:18 PM
powerflow's Avatar
Default Re: painting my jdm thin sidmoldings... HOW? (teh Dirka)
If they are raw plastic, use guidelines to prep/paint the parts correctly. You can leave the texture and paint over it, the texture will be visible in the color/surface. You could sand the surface and apply a quality 2K high build primer, then cure - sand - paint. Raw plastic tends to tear when sanded with coarse grit, you'll be better off priming instead of trying to completely sand out the texture.
Old Sep 20, 2008 | 11:59 AM
teh Dirka's Avatar
where is the guideline? ill search it, bt if you got it post it up for me.
Old Sep 20, 2008 | 08:32 PM
switchjv's Avatar
shoot a couple of coats of high build primer and sand smooth. then paint.
tweensquirt
Acura TSX
Mar 12, 2012 05:58 AM
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
wdissident
Paint and Body
Jan 25, 2009 09:09 AM
peiku
Jul 25, 2005 10:49 PM
deeweezy
Aug 17, 2003 07:19 AM
