Basically Stock 00' Civic EX
Old Sep 19, 2008 | 12:06 PM
syro's Avatar
Default Basically Stock 00' Civic EX
What would be a relatively cheap way to buy a few things to increase HP/torque in a stock 00' Civic EX? Like a few smaller parts, etc. that I could buy to start with. I'm even thinking about looking into an Integ VTEC for an engine swap since that seems like a common way. Thanks in advance.
Old Sep 19, 2008 | 12:30 PM
Dkober101's Avatar
Default Re: Basically Stock 00' Civic EX (syro)
you can buy CAI wich really dosnt give you much hp (6-8) nore can you tell a huge difference but it dose give your car little more sound.
Old Sep 19, 2008 | 12:39 PM
EJ8_Enthusiast's Avatar
Ive read cold air intake doesnt give that much of an increase, 6 to 8 accurate?
Old Sep 19, 2008 | 01:31 PM
alphalanos's Avatar
Default Re: (EJ8_Enthusiast)
maybe 3-5. Barely anything. You have an EX, you can get a little more than a non VTEC but still not a whole lot. I/H/E might get you 10-15whp at most.
Old Sep 19, 2008 | 01:53 PM
koa's Avatar
koa
Default Re: (alphalanos)
The only way to see any kind of power out of a SOHC is boost. but the simplest is nitrous.
Old Sep 19, 2008 | 02:41 PM
naRIPSTA's Avatar
I am my avatar
For power, there's not much you can do. You can try researching up on turbo setups, there's budget builds out there that you can find.
If you want a swap, I'd go with an LS just cause it's pretty cheap. But that's me of course.
Old Sep 19, 2008 | 02:46 PM
Dkober101's Avatar
you know what dude the best thing to do whit that certant d series ( i take it that you have a y8) get going about 75-80 mph on the high way and push in your clutch jam it in 2nd gear and just let the clutch go. then get mom and dad to buy you a LS swap
Old Sep 19, 2008 | 02:53 PM
Hanmin's Avatar
Default Re: Basically Stock 00' Civic EX (Dkober101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dkober101 &raquo;</TD></TR><TR><TD CLASS="quote">you know what dude the best thing to do whit that certant d series ( i take it that you have a y8) get going about 75-80 mph on the high way and push in your clutch jam it in 2nd gear and just let the clutch go. then get mom and dad to buy you a LS swap </TD></TR></TABLE>
tried it in a dx... wouldn'y be surprised if it survived
Old Sep 19, 2008 | 02:55 PM
BryanM.'s Avatar
Resident Gearhead
CAI won't do much, wastes of $ IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syro &raquo;</TD></TR><TR><TD CLASS="quote">I'm even thinking about looking into an Integ VTEC for an engine swap since that seems like a common way.</TD></TR></TABLE>
Not exactly cheap, but if <U>you</U> think that is cheap, also consider boosting your current motor.
LOL wut? Is this what you did?
Old Sep 19, 2008 | 03:00 PM
hondamark35's Avatar
weight... that's the biggest thing holding the EX back.
extras add up quick, power everything, sunroof mechanism... and so on. the good part for your case, you get to pick which things you are willing to get rid of (where as with a DX you have to go find the things you wanted but didn't get...)
you've got the best factory D-series manifolds honda ever sold in the us, start there. you can get a chip, intake (cold air or short ram with heat deflector box) mild exhaust upgrade; don't spend too much here. the difference with a mostly stock civic between a mid-grade kit and the super high-end JDM-spanker won't be noticed.
enjoy!
Old Sep 19, 2008 | 05:29 PM
formby's Avatar
what i would do if i just got into the game now.
hind sight is 20/20
i would start with an alarm stealth installed. i payed 500 for alarm and install @ a best buy far away from where i live.
then i would do the suspension and upgrade pads fluids and a new set of blanks along with a radiator and slim fan maybe detachable steering wheel.
by this time you might need tires so rims and tires are in order...
all while i peace together parts for a solid DIY FI kit.
or a bolt on edlebrock turbo kit or even a fullrace kit and have it tuned with a p28 on a dyno . your pick
ohh and i would buy a couple short blocks cheap, down time insurance
EDIT:
forgot the most important thing....
if you plan on racing see the rules for the class you will be competative. and take your time dont rush
vdubbin95
Jun 29, 2011 08:31 AM
sebZZ
Jun 11, 2005 11:25 AM
-Fluffy-
May 6, 2004 06:54 PM
DK4200
16
Jun 5, 2003 11:17 AM
