Rear LCA bushings same as 88 CRX?
I'm fairly sure they are, but since you can't get replacement bushings for the ITR rear LCA, will the ones from the 88 CRX Si work? Part # 25 in this pic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">Isn't the ITR bushing stiffer. Beside that bushing diameter is the same for ITR, 88 civic/crx, 89-01 intergra and civic 88-00.</TD></TR></TABLE>
???? #24 is for the 88-00 Civic and non-ITR 94-01 Integra rear LCA, #25 is for the 88 CRX Si, and maybe the ITR LCA.
AFAIK the 88 CRX Si is the only USDM Honda to share the same style rear LCA as the ITR. I think that the bushing diameter would be different between the non-R style LCA and the R style. As for the ITR busing being stiffer than an 88 CRX Si? I haven't seen durometer data for either so I have no idea.
???? #24 is for the 88-00 Civic and non-ITR 94-01 Integra rear LCA, #25 is for the 88 CRX Si, and maybe the ITR LCA. AFAIK the 88 CRX Si is the only USDM Honda to share the same style rear LCA as the ITR. I think that the bushing diameter would be different between the non-R style LCA and the R style. As for the ITR busing being stiffer than an 88 CRX Si? I haven't seen durometer data for either so I have no idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">why go through all that trouble a new itr lca is only like 42 bucks</TD></TR></TABLE>
Cheapest I've seen them is $56/ea LCA. The bushings are $13.72 each. So that's less than 1/2 the price. I plan on pressing in all new bushings this winter anyway so adding an extra 5 minutes of work vs buying new isn't a big deal.
Do you have a link for them at $42? If the bushings end up being different I might have to go that way.
do u guys have a part number for the ITR lower control arm? They dont have the model selection for TYPE R 3DR on acuraautomotiveparts anymore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">
AFAIK the 88 CRX Si is the only USDM Honda to share the same style rear LCA as the ITR. </TD></TR></TABLE>
All 1988 Civics/CRXs in the USA came with the ITR-style LCA. Then in 89, they were all changed, of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">do u guys have a part number for the ITR lower control arm? They dont have the model selection for TYPE R 3DR on acuraautomotiveparts anymore</TD></TR></TABLE>
52350-ST7-R00 ARM, R. RR. (LOWER)
52360-ST7-R00 ARM, L. RR. (LOWER)
Found that on acuraautomotiveparts.org looking under 2000 Integra Type-R 3dr
Speed PHreak
40
Apr 26, 2005 09:24 AM
