OBD2a into 2b, I'm confused.
Old Sep 19, 2008 | 07:48 AM
Xscort's Avatar
Default OBD2a into 2b, I'm confused.
Ok I've looked at the FAQs, but I am rather confused. I've already done an obd2a into my EJ1 flawlessly. I now have another Civic, 99 EX. Here in SC, these J/y are scarce with obd2b b18b's, and I've found some decent obd2a(96-99) b18b's.
I'm in a conflict. I will be turboing within the next 3-4months. But in the meantime, I want my car to be close to stock as far as electrical and wiring goes>>retaining obd2b.
So all in all, I will be ordering a obd2a b18b, what are my best options in retaining obd2b? Order an obd2b engine harness from a J/y and hope there is one available?? Any other changes other than an obd2b ECU?
We don't have any inspection here in SC, but I love my environment and want to keep it/my build clean as possible, lol! Unless I'm going to have to convert to obd1 for EMS purposes.
Help me out please!!!
Modified by Xscort at 4:26 AM 9/20/2008
Old Sep 19, 2008 | 08:37 AM
LA_HONDAS's Avatar
Default Re: OBD2a into 2b, I'm confused. (Xscort)
you put any OBD motor in any OBD car as long as you keep your stock motor harness
you gonna need obd2 to obd1 jumper harness so you can tune it http://rywire.com and obd1 ecu
Old Sep 19, 2008 | 09:35 PM
Xscort's Avatar
i totally understand that concept. but, i can get good deals on a obd2a b18b, could i just get a 96-99(obd2a) teg motor and use a 99-01 obd2b(civic/integra) engine harness on it?? or are there a few plugs that are incompatible?
Basically, if i do order the obd2a engine, should i try and grab an obd2b engine harness and use on the obd2a engine, or the plugs are different??? and eventually i WILL get and obd2b to obd1 conversion harness for tuning.
Modified by Xscort at 4:13 AM 9/20/2008
Modified by Xscort at 4:25 AM 9/20/2008
Old Sep 20, 2008 | 07:07 AM
LA_HONDAS's Avatar
Default Re: (Xscort)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS &raquo;</TD></TR><TR><TD CLASS="quote">as long as you keep your stock motor harness</TD></TR></TABLE>
USE YOUR STOCK ENGINE HARNESS ON THE MOTOR YOU GONNA USE EVERYTHING IS PLUG & PLAY YOU MIT HAVE TO MAKE SOME WIRES LONGER AND YOU MIT HAVE CHANGE THE IAT PLUG AND MAKE THE WIRES LONGER FOR IT
ONLY USE THE ENGINE HARNESS THAT COME OUT THAT CAR
Old Sep 20, 2008 | 10:27 PM
Xscort's Avatar
Calm down bud! Geez. Trust, obd2 swaps are more confusing than the obd1. Thanks for the input. I will be returning to this post once I begin the install.
2manytoyz
Apr 11, 2012 04:49 PM
jdmek(98)
Dec 1, 2009 02:36 PM
Cristorey34
Aug 6, 2005 07:36 AM
DGAF
Jul 1, 2005 08:16 PM
Adam.
Sep 28, 2002 07:11 AM
