D15B2 installed, car not wanting to go into gear.
Well I installed my D15B2 from Attarco engines today. I used my original CX tranny and everything bolts up right. Well I put the car into gear and try to drive it and it doesn't go into gear. I put it into first and it still rolls when I push the car.
What could the problem be?
Well the clutch fluid is at the right amount because I bled the clutch and added brake fluid.
I messed with the axels and tried turning them while my brother had the car in gear and they didn't move.
I can check the clutch, but I would suspect that since the motor only has around 25-30K on it the clutch wouldn't be worn out-I may be wrong.
integracura
Apr 18, 2007 11:18 AM
