Coolant temp sensor
Old Sep 18, 2008 | 05:04 PM
jrod9989's Avatar
Default Coolant temp sensor
Does anyone know wich coolant temp sensor is for the ecu on a obd0 b16. cause the one the one under the distributor didn't shut off the temp gauge and i think there is one next to the oil filter a two wire one and a single wire one. i have unhooked and rehooked all of them up. it trows a code 6 with key on engine off and 6 and 7 while running.
Old Sep 18, 2008 | 05:14 PM
89hatcher's Avatar
the one by the oil filter is the one to turn on/off the radiator fan.
Old Sep 18, 2008 | 06:20 PM
jrod9989's Avatar
Default Re: (89hatcher)
alright i got ya but my car doesn't start when its cold so it is thinkin that it is cold and it only throws code 6 key on engine off and 6 and 7 while running and both are for the coolant temp sensor
Old Sep 18, 2008 | 07:18 PM
89hatcher's Avatar
did you change the sensor under the distrbutor? change it its only a couple of bucks.
TNight
Jul 17, 2014 01:20 PM
busyychild
May 6, 2008 11:09 AM
whiterex
Feb 28, 2005 02:57 PM
90civichbsi
Oct 2, 2002 09:07 AM
JoshM
Jun 2, 2002 06:11 PM
