someone please confirm this for me...
Vehicle: 98 GSR
Header: JDM ITR 4-1
Cat: Modified omnipower adjustable with 4.5" extension welded in
Cat-Back: USDM 01 ITR
Situation: I'm unhappy with the sound of my exhaust, and I'm pretty sure it's because of the lack of resonators in my setup. If I remember correctly, the USDM ITR cat-back doesn't have any resonators in it, and obviously my straight-through test pipe doesn't either.
So, I went on a quest to find a resonated test pipe with a 2.5" inlet to fit my JDM ITR header. I found the PWJDM one that is adjustable from 14.5"-19.5" but it is no longer in production.. but i think this guy will do the trick.
http://www.jhpusa.com/store/pc...=3528
based on what i'm reading, it will... 2.5" inlet, resonator. with my JDM ITR header and ITR cat back, this test pipe *made for* a 97-01 ITR will be the correct length, correct? i just need someone to confirm my logic here.
Thanks in advance.
Modified by kapoosh valve at 9:02 PM 9/18/2008
Header: JDM ITR 4-1
Thanks in advance.
hm, well, my exhaust sounds raspy from inside the cabin. i assumed that it was due to the test pipe and couldn't recall if the stock ITR b pipe had a resonator in it or not.
anyone with a similar setup having a similar sound? maybe i've got a leak.
test pipe could have somthing to do with it, or you could also have a leak, its probally the testpipe
is all you have done to your motor is a jdm 4-1 and itr exhaust?
if so just buy a stock jdm type r cat, people make pretty good power with that setup and its super quiet and sounds good , no rasp
the T1R test pipe will work, you will need the USDM lenght. but i am not sure if that will solve the raspy exhaust.
and if you have a secondary O2 sensor, you will have to well a bung on either the new test pipe (T1R) or on the exhaust pipe.
or if you are missing the resonator all together, you can get an after market one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">test pipe could have somthing to do with it, or you could also have a leak, its probally the testpipe
if so just buy a stock jdm type r cat, people make pretty good power with that setup and its super quiet and sounds good , no rasp</TD></TR></TABLE>
the only mods are AEM intake, jdm 4-1 header, test pipe, and ITR exhaust.
if i remember correctly, my buddy that did the welding welded the two extension pieces together, and then welded them to the test pipe, but i think he missed the two places closer to the flanges. it felt pretty solid before i put it back in place, though.
i was thinking about just paying the $160 for a custom hi-flow cat from kteller, but i'm afraid that the *hi-flow* won't be restrictive enough to fix my problem.. which is why i was hoping to go with a resonated test pipe. i got an emissions extension for 2 years last week cause my car was too low. w00t.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">To my knowledge you'll have to find a T1R TP used if you want one. I believe in am correct in saying that they have been discontinued. </TD></TR></TABLE>
it appears that JHP has them in stock, but i've had issues with their site being inaccurate in the past.
I could be wrong but i reckon it was th' USDM ones that whar discountinued. ARRRRgh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_320R »</TD></TR><TR><TD CLASS="quote">the T1R test pipe will work, you will need the USDM lenght. but i am not sure if that will solve the raspy exhaust.
or if you are missing the resonator all together, you can get an after market one.</TD></TR></TABLE>
why would i need the USDM length one if i have a JDM header?
4-1 JDM header - Omnipower JDM test pipe - ITR like mid pipe - Apexi WS2 exhaust
I also have the raspy sound, so I need to quiet it a bit.
Would a resonated test pipe with a 2.5inlet and 2.25 outlet do the work ?
It's hard to find the T1R, is there any knockoff out there ?
Tuner Eddy
Feb 14, 2012 08:35 PM
kapoosh valve
Oct 12, 2008 03:38 PM
vtecpowerd
Jan 6, 2006 05:29 AM
