serious help o2 sensor issue
Old Sep 18, 2008 | 03:04 PM
skylude3's Avatar
Default serious help o2 sensor issue
i have a 99 civic ex i broke my o2 awhile back and just replaced it my cel is on with a code po 135 o2 sensor heater circuit bank 1 sensor 1 how can i bypass ie fix i failed emissions and need help
Old Sep 19, 2008 | 03:56 PM
skylude3's Avatar
Default Re: serious help o2 sensor issue (skylude3)
help me please someone ive searched for hours and driven illegally just to use the internet
Old Sep 19, 2008 | 04:33 PM
civicjoe's Avatar
try disconnecting the battery for a minute then connecting it. This will clear the code.
Old Sep 19, 2008 | 04:37 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: serious help o2 sensor issue (civicjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">try disconnecting the battery for a minute then connecting it. This will clear the code.</TD></TR></TABLE>
Right, the ECU doesn't know the problem is fixed until you reset it. I practically guarantee this is the issue.
Old Sep 19, 2008 | 04:54 PM
skylude3's Avatar
Default Re: serious help o2 sensor issue (mcvtec)
i have a reader that clears it and ive done it a **** ton of times i broke the sensor so theres a short some where help
Old Sep 19, 2008 | 05:01 PM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylude3 &raquo;</TD></TR><TR><TD CLASS="quote"> i broke the sensor so theres a short some where help</TD></TR></TABLE>
LOL wut? Please explain. You stated you replaceced the 02 sensor.
Old Sep 20, 2008 | 07:56 AM
Burnt Toast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylude3 &raquo;</TD></TR><TR><TD CLASS="quote">i have a reader that clears it and ive done it a **** ton of times i broke the sensor so theres a short some where help</TD></TR></TABLE>
Just reset the ecu. Here's how:
pull that fuse and reinstall it. You will lose your presets on your radio.
Old Oct 3, 2008 | 04:32 PM
skylude3's Avatar
ok it broke awhile ago and i just replaced it my old one got bashed by somthing and its telling me the a heater circuit problem is there a way to jump it for the ecu
Old Oct 10, 2008 | 03:43 PM
skylude3's Avatar
yo i need help please theres got to be a way to jump it or find out where the short is if some one can help please email me at skylude3@yahoo.com
Old Oct 10, 2008 | 04:51 PM
BuiltforSin's Avatar
It's going to come back on no matter what. Just fix it!
Old Oct 10, 2008 | 04:56 PM
tx_ej8_49's Avatar
Did you replace it with a craptermaket brand or OEM? Check your fuses and make sure they are all good, under the dash too. Then take the top off your ECU and smell it, had a o2 heater code for almost a year before i narrowed it down to the bad ECU. Welding exhaust with the battery connected it not a good idea....
Old Oct 10, 2008 | 04:58 PM
tx_ej8_49's Avatar
Also there is a TSB for the main harness that runs underneatht the intake manifold, over time the harness rubs against the manifold bracket and will cause the o2 wires to short out. Fuse 15 will be blow under the dash and the ECU smell like "burnt" if it is bad. Correction: Remove intake manifold bracket(can be a pain in the 4ss) and fix any frayed wires. Check the ecu. If all is replaced and well, reset the ECU and pray......pray.
dc2go
Mar 29, 2010 05:31 PM
die_lawn
Apr 7, 2008 05:30 AM
Myh4tch
Apr 4, 2005 08:34 AM
stehigs321
Jan 1, 2005 07:14 AM
suckawillis
Dec 20, 2004 05:29 PM
