h/f tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfcd5 »</TD></TR><TR><TD CLASS="quote">just get the tranny too. its like playin basketball with a flat ball. at least you hav a ball to play with but one with full air would make things a lot easier and better.</TD></TR></TABLE>
H22/H23/F22/F23 = Same transmission.
The gearing may be different with each variation, but the the transmissions themselves are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfcd5 »</TD></TR><TR><TD CLASS="quote">so wat do you mean by, one is male and one is female?</TD></TR></TABLE>
the half shaft (the part that connects the driver side axle to the transmission) is different between the H and F series. On the H series the half shaft has a male end sticking out for the axle to slide onto whereas on the F series the half shaft has a female end for the axle to slide into. I hope I didn't get that backwards, it's been a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">....The gearing may be different with each variation....</TD></TR></TABLE>
the gearing is different
http://www.cb7tuner.com/vbb/showthread.php?t=37839
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
http://www.cb7tuner.com/vbb/showthread.php?t=37839</TD></TR></TABLE>
I know the gearing is different, that's why I mentioned it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">and I was showing the difference</TD></TR></TABLE>
and I'm quoting you for no reason.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91CivicSiR1989 »</TD></TR><TR><TD CLASS="quote">I have an f22 swap with an f series tranny and h series halfshafts</TD></TR></TABLE>
Lovely post, but you don't have a driver side F axle
sorry to thread jack, but while you guys are all on this topic I had a couple questions. I currently have accord shafts on my h22 accord tranny combo in my 92 accord but was thinking about going with upgraded prelude shaft/half shaft when i swap the engine in my 94 accord. However, I have heard of people having issues with binding when doing this but have read (in the faq swap section) that if i uses some washers? it will fix this? does anyone have any extra info on this?
I was refering to 94H22accord 's post on this forum....
http://www.accordinglydone.com...?t=29
"- used Prelude shafts - much stronger - the splines are about 1/16 of an inch too long - get some industrial strength washers, and grind if necessary to fit onto hub "
Thanks guys
Thanks guys
JDMroyEG5turbo
Mar 15, 2006 07:29 AM
