help with ecu.. please.
Old Sep 17, 2008 | 05:42 PM
dirtylilhonda's Avatar
Default help with ecu.. please.
i have a p13-jo1.i pretty sure it's jdm. it is obd 1 but has 4 plugs. and with the big bold 4w on this side i'm assuming its for the 4 wheel steering. ok can i use this for my h22a and if so what do i have to do to make it run right.
Old Sep 17, 2008 | 05:44 PM
94EG8's Avatar
Seagull Management
Default Re: help with ecu.. please. (dirtylilhonda)
the only 4 plug OBD1 ECUs i'm aware of are JDM Automatic units.
Old Sep 17, 2008 | 05:51 PM
Default Re: help with ecu.. please. (94EG8)
that would explain the hatch driving like *** with this ecu.. i tried looking it up but i can't find anything about it. anyplace you know i can find out what i need about this ecu?
Old Sep 17, 2008 | 05:58 PM
94EG8's Avatar
Seagull Management
thats really all i know about it, but heres a link to ff-squad http://technet.ff-squad.com/wiring.obd1.htm, compare to the second ECU in the first pic, if it matches its a JDM automatic OBD1 ECU. Thats about all I can tell you. Katman might know more though.
Old Sep 17, 2008 | 06:10 PM
yeah thats it... in that case the idling would change i know but why does it run like ****? it has now where near the power it had and it almost acts like its pulling in and out, like its trying to get more power... i didn't even stay in it long enough to see if the v-tec kicked in or what the rev limiter was set at.. any ideas? and how could i talk to that guy you mentioned?
Old Sep 17, 2008 | 06:13 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtylilhonda &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats it... in that case the idling would change i know but why does it run like ****? it has now where near the power it had and it almost acts like its pulling in and out, like its trying to get more power... i didn't even stay in it long enough to see if the v-tec kicked in or what the rev limiter was set at.. any ideas? and how could i talk to that guy you mentioned?</TD></TR></TABLE>
When you say it doesn't have the power it did before... did you have another ECU in and then switch to this one? you can try PMing katman, he's on H-T.
Old Sep 17, 2008 | 06:32 PM
yeah i have a p0a-a01 in the hatch now. it works fine. really good actually. the only problem is the rev limiter is kickin in a 6200 rpm's... which is restricting the the amount of fun i could be having with this built h22a..
Old Sep 17, 2008 | 06:36 PM
oh wow? if i'm right that is from an accord with a f22b2??? thats not vtec right?
Old Sep 17, 2008 | 06:39 PM
HOW IS MY VTEC WORKING?
Old Sep 17, 2008 | 06:46 PM
THC07's Avatar
built?
wow! get the correct ecu asap, your damaging your H, thats H abuse, not kewl.
EDIT the p0c is non-vtec.
Modified by THC07 at 7:54 PM 9/17/2008
Old Sep 17, 2008 | 06:52 PM
Default Re: help with ecu.. please. (THC07)
YEAH PISTONS, RINGS, STAGE 2 CAMS, AEM FUEL RAIL, fidanza FLYWHEEL, 6 puck racing clutch. the ecu i have now runs it fine but like i said rev limiter kicks in at 6200.. and now i don't understand how my vtec is working on a non-vtec ecu. i'm lost
Old Sep 17, 2008 | 06:58 PM
THC07's Avatar
maybe because f22b p0a is a vtec motor/computer
your pistons, rings, stage cams... omg nvm
go get a tune!
starting with the correct ecu, like tomorrow. Your H hates you right now im sure.
Old Sep 17, 2008 | 07:03 PM
i'm low on money or i would already have an ecu for it... my buddy has a ecu with hondata that had my hatch pulling to 11,000 with no problem. and i have to atmit its the fastes thing i've ever been in. but now i have a 6200 rpm ecu and no money to get the hondata he has.. i was hoping this ecu would work but its giving me problems(the p0a-a01)
Old Sep 17, 2008 | 07:10 PM
THC07's Avatar
Hondata is wasted money, dont even stress over it, you dont need it.
you just need a chipped computer and a trip to a dyno tuner. all that will cost half what a hoedata system will cost you. think think it was fast with an untuned computer w/ built motor... no!
dont ever rev to 11k again. ever!
you really need to read up on some things, your about to destroy your motor and learn the hard way.
Old Sep 17, 2008 | 07:13 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtylilhonda &raquo;</TD></TR><TR><TD CLASS="quote">i'm low on money or i would already have an ecu for it... my buddy has a ecu with hondata that had my hatch pulling to 11,000 with no problem. and i have to atmit its the fastes thing i've ever been in. but now i have a 6200 rpm ecu and no money to get the hondata he has.. i was hoping this ecu would work but its giving me problems(the p0a-a01) </TD></TR></TABLE>
Yeah man, go get a tune.
Old Sep 17, 2008 | 07:18 PM
i know... i jus need money. i'm broke.
Old Sep 19, 2008 | 02:31 PM
hey this ecu has j-mt on it. doesn't that mean it is manual trany... ???
blink_977
Dec 22, 2008 06:59 PM
Linh.
Dec 7, 2008 08:57 AM
Eli Mac 67
Jun 11, 2007 04:45 PM
SLVR-DC5
May 31, 2006 10:13 PM
tomlinson619
Mar 1, 2006 03:41 PM
