H22a Crankshaft Turning Torque
Old Sep 17, 2008 | 04:42 PM
kornerk12's Avatar
Default H22a Crankshaft Turning Torque
What should the turning torque be on an h22a ? This can not be measured with the timing belt on... can it ?
Old Sep 17, 2008 | 07:15 PM
PyroProblem's Avatar
Default Re: H22a Crankshaft Turning Torque (kornerk12)
I dont believe there is an actual "spec" for turning torque. This would all be affected by bearing clearances,piston to wall clearances, assembly lube, ring tension, (you get the idea),etc.
The idea behind this (to me) is to check for any inconsistencies that could potentially damage the engine and cause premature failure...
So the best time to measure this is during engine assembly as your torquing down mains,installing pistons, rods,etc...
You want each component youre checking to be similar to the others both in "break away" torque and constant "turning" torque.
Youll need a good digital torque wrench to be accurate...
And no, you cant have the timing belt on.
Old Sep 17, 2008 | 07:33 PM
kornerk12's Avatar
Default Re: H22a Crankshaft Turning Torque (PyroProblem)
couldnt you use a beam style torque wrench ?
Old Sep 17, 2008 | 07:47 PM
I suppose you could if you feel it can be accurate enough...
Snap-on makes a nice electric torque wrench
http://buy1.snapon.com/catalog...talog
I use this one personally
Old Sep 18, 2008 | 12:04 PM
kornerk12's Avatar
well does anyone have a general spec to go by ?
Old Sep 18, 2008 | 02:16 PM
98vtec's Avatar
moderator emeritus
mine was 9-10 ft lbs.
smxcan
Jan 12, 2009 07:17 PM
RaceBred
Jun 15, 2001 11:14 PM
