92 DX D15 B7 broke crankshaft
Old Sep 17, 2008 | 04:10 PM
skipper56's Avatar
Default 92 DX D15 B7 broke crankshaft
Mechanic says crank bolt came loose, pulley came loose, keyway and crank damaged beyond repair. Says it is not uncommon. His least expensive solution was to replace engine (rather than rebuild). Any other options? Rebuild - where can I find the parts?
Old Sep 17, 2008 | 04:12 PM
-[95cxhatch]-'s Avatar
Default Re: 92 DX D15 B7 broke crankshaft (skipper56)
my old lx did the same ****...
this is what I did... I bought another crank pulley and key... filled the chipped part of the crank with jbweld and put the pulley back on. This held and worked great for a year. Up until I started running the AC... then it broke again.
If you just need this car to get you somewhere I would try it... If you want to make it a "race car" then I would just swap in a z6 or d15b SOHC. Or even better move up to a b series.
Old Sep 17, 2008 | 04:13 PM
BTW I also have a d15b7 crank I will sell for 30 bucks plus shipping. That is if you want to fix the motor you have... Hell I even throw in my old d15b7 if you want it.
Old Sep 17, 2008 | 04:23 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skipper56 &raquo;</TD></TR><TR><TD CLASS="quote">Mechanic says crank bolt came loose, pulley came loose, keyway and crank damaged beyond repair. Says it is not uncommon. His least expensive solution was to replace engine (rather than rebuild). Any other options? Rebuild - where can I find the parts? </TD></TR></TABLE>
He's right, its not uncommon. The crank bolt will back out on its own sometimes, unless your actually trying to remove it and then it wont budge. I've seen people weld up the end of the crank, grind it down and put on a new harmonic balancer before. you could replace the crank too. but honestly if you're paying a mechanic it usually is cheaper to just replace the engine. If you were closer i'd give you a crankshaft and a harmonic balancer, i've got 3 D15B7s in a corner of my garage waiting to be stripped for scrap aluminum, all have good cranks though.
Old Sep 17, 2008 | 04:46 PM
skipper56's Avatar
Small world. Just found out someone I know had the same thing happen and he had to get a used engine from Texas. None local because they seem to be popular for racing or such.
I haven't yet seen the damage myself. May be tempted to do the weld thing and get by.
Sad part is I just had a rebuilt a/c compressor put in.
I will let you know about purchase of the crank. I am capable of a rebuild. Just never looked for Honda parts.
methos713
Jun 7, 2016 10:02 PM
KAITO
Nov 29, 2009 06:36 PM
James89DX
Dec 29, 2008 06:23 PM
RAB
Oct 13, 2004 05:45 PM
Jockobo
Oct 21, 2002 11:53 AM
