DOHC ZC fails emissions...
Old Sep 17, 2008 | 04:06 PM
White91EF's Avatar
Default DOHC ZC fails emissions...
91 Sedan, DOHC ZC swap, PG7 ECU... Runs great, burns a little oil, new o2 sensor. I took it in for emissions, here are the test results:
HC (PPM):
Cruise Limit...180
Cruise Emissions...193
Idle Limit...220
Idle Emissions...226
CO (%):
Cruise Limit...1.3
Cruise Emissions...2.97
Idle Limit...1.2
Idle Emissions...0.38
Failed HC at cruise and idle, and failed CO at cruise only.
Also my CO+CO2% at cruise was 16.17 and at idle was 14.58, O2% at cruise 0.45 and at idle 1.39...
I've already replaced the o2 sensor, could my tps be out of adjustment? Why else would it run so rich? Catalytic converter?
Old Sep 17, 2008 | 04:11 PM
Jonknee's Avatar
Default Re: DOHC ZC fails emissions... (White91EF)
is ur timing ok
Old Sep 17, 2008 | 04:14 PM
White91EF's Avatar
Default Re: DOHC ZC fails emissions... (Jonknee)
i know the cam timing is good, i haven't put a light on it though... so ign timing could be off
Old Sep 17, 2008 | 04:31 PM
redef90si's Avatar
timing or cat imo
Old Sep 17, 2008 | 05:27 PM
White91EF's Avatar
Default Re: DOHC ZC fails emissions... (redef90si)
cool i'll get a timing light on it tomorrow...any other suggestions?
Old Sep 17, 2008 | 05:29 PM
91DBSexyTime's Avatar
thats weird, I passed emissions with a check engine light and running rich, maybe I got lucky, slap on a new cat.
Old Sep 17, 2008 | 06:36 PM
davens's Avatar
Try changing back to the pm6 for the test.
Old Sep 17, 2008 | 08:26 PM
acmoc's Avatar
Default Re: (davens)
our cars are like 15 years old, and before we got them, they probably were never maintained rite.
I've owned 2 crx's. It's always the 15 year old cat and muffler that need changing
Old Sep 17, 2008 | 08:54 PM
tico's Avatar
If ur running the pg7, no cat, out of timing ur guaranteed to fail emissions. put in a pm6 it has leaner fuel maps get your timing accurate use a cat, i would recommend a denso o2 sensor since that is a honda part. alot of the general sensors run real rich. i would also do a tune up and oil change right before ur smog inspection.
Old Sep 17, 2008 | 10:23 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
wow didnt know there was emissions in spokane.
Old Sep 18, 2008 | 12:10 AM
White91EF's Avatar
Default Re: (jdm_dc_fan)
yea i was thinking of putting a pm6 in there to lean it out a little, and yea it has the original stock cat and muffler, theres no leaks but it is 17 years old so the cat could probably be replaced...the o2 i put in it was an used oe honda sensor, but i know it was good it came out of my buddys hatch.. I dont know if this would be related to emissions but I think my tps might be out of adjustment i haven't tested it yet but at full throttle sometimes it will bog out for a second, i've already done a tune up replaced plugs/wires/cap/rotor/ignitor/fuel filter... would a bad cat cause me to fail both hc and co?
Old Sep 18, 2008 | 06:19 AM
Jonknee's Avatar
Default Re: (White91EF)
Thats weird, tps sensors rarely need to be adjusted, which is why they are usually just riveted on the throttle body.
Old Sep 18, 2008 | 12:55 PM
White91EF's Avatar
Default Re: (Jonknee)
well mine is screwed and not rivited to the throttle body so i know its not the original tps... i'll have to borrow a volt meter to test it... i believe its supposed to be .45 at idle and 4.5 at WOT is that correct?
Old Sep 18, 2008 | 01:22 PM
Master23's Avatar
Good thing we don't do emission testings here in MN anymore. hehe.
Old Sep 18, 2008 | 01:49 PM
Jonknee's Avatar
Default Re: (Master23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White91EF &raquo;</TD></TR><TR><TD CLASS="quote">well mine is screwed and not rivited to the throttle body so i know its not the original tps... i'll have to borrow a volt meter to test it... i believe its supposed to be .45 at idle and 4.5 at WOT is that correct?</TD></TR></TABLE> That is right.'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">Good thing we don't do emission testings here in MN anymore. hehe.</TD></TR></TABLE> Lol u just wait.
White91EF's Avatar
Yea! you guys are lucky! emissions can be a pain in the a$$
Old Sep 18, 2008 | 06:44 PM
AK_CRX's Avatar
I live in Alaska and it looks like we have the same limits as you have listed... I passed a dohc zc w/pg7 ecu, gutted cat and no muffler... failed the first time, pour in a bottle of Heet (yellow bottle) and passed with flying colors. People call BS on this everytime I mention it, but it ALWAYS works for me. I just used a full bottle on a 1/4 tank of reg gas in a stock dx sedan with 238k and it barely registered on the tests. Try it, it costs .99c a bottle. If one bottle don't work, put in another.
Old Sep 19, 2008 | 12:19 AM
White91EF's Avatar
Default Re: (AK_CRX)
yea a friend of mine suggested throwing in a few bottles of that cheap octane booster on a quarter tank of 92 octane gas and retard the timing a little bit and i should be good.. i got a new cat and exhaust today (used but supposedly good, i guess i'll find out)... now the kid i bought the car from told me today that he thinks he set the tps at .5 and 5.0 cuz that was the closest he could get it (sh*tty multi meter i guess) would that be enough to fail emissions?
Old Sep 19, 2008 | 01:27 AM
24TEN's Avatar
PHANTOM MENACE
As stated above, it's your ECU. New cat would definitely help but it's your ECU that's making your car run rich. I'm from CA and you know we don't get any breaks when it comes to smog. Mine barely squeaked by on a PG7 and I mean just barely (at the max limit for 15 mph test to be exact). Later I switched to a PM6 ECU and passed with room to spare.
Old Sep 20, 2008 | 07:40 AM
djrockytharp's Avatar
hc and co are what the cat helps elimintate. so yeah, slap a new cat in there and you'll be fine. if your cats original then yeah its definately the problem.
Huffy75
Aug 25, 2017 08:29 PM
Andrew760
Jul 24, 2011 02:07 PM
PINKS
Dec 3, 2006 04:41 PM
NoVALude
Nov 20, 2006 11:02 AM
after_effx
Apr 30, 2004 10:37 PM
