95 Accord LX speakers
Old Sep 17, 2008 | 03:16 PM
kornerk12's Avatar
Default 95 Accord LX speakers
What size speakers are in this car ? Front and rear
Old Sep 17, 2008 | 04:42 PM
TheMuffinMan's Avatar
He knows where you live!
6x5 all around I believe?
Old Sep 17, 2008 | 08:50 PM
slomofo's Avatar
GDD Member
Default Re: (TheMuffinMan)
6.5" up front and 6.5" out back, but 6x9s were optional rear speakers which came in some EX/LXs, most Special Editions, most EX coupes, and all V6.
Old Sep 17, 2008 | 08:58 PM
^ All EX got the 6x9
*edit*
Damn it, can't confirm this 100% crutchfield won't let me filter
Basically open the trunk and if they're oval they're 6x9, if they're a circle you have 6x5
Modified by TheMuffinMan at 1:22 AM 9/18/2008
Old Sep 20, 2008 | 12:20 AM
jwicecold's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">^ All EX got the 6x9 </TD></TR></TABLE>
TRUE TRUE!!! so you got bout 5 1/4 to 6 1/2 in front and 6x9 in rear!!
Old Sep 20, 2008 | 11:18 AM
erk89's Avatar
Default Re: 95 Accord LX speakers (kornerk12)
there deffinatly 6.5" all the way around, i used the brackets from and ex and cut these little tabs off so i could have 6x9"s in the back.
Old Sep 26, 2008 | 04:22 PM
kornerk12's Avatar
Default Re: 95 Accord LX speakers (erk89)
how do I mount the 6x9s in the rear ? There is a bracket there so i can fit the 6.5s and it looks like without it 6x9s would be a close fit.
Old Sep 26, 2008 | 06:06 PM
erk89's Avatar
I put in 6x9 in my accord lx but dont recommend it, but heres more info if wanted
https://honda-tech.com/zerothread?id=2259873
6x9's do get pretty distorted when it gets turned up though, more work than what its worth
Old Sep 26, 2008 | 06:22 PM
mkrieger500's Avatar
Ihave a 1993 accord and I had 4in in the front in factory enclosures. It was premium sound i think? There should be 6.5in holes in the front. The back could be 6.5in or 6x9's.
Old Sep 29, 2008 | 03:14 PM
kornerk12's Avatar
Default Re: 95 Accord LX speakers (mkrieger500)
ok in my 95 lx i have 6.5s all around.
Also the factory speakers use a harness that plugs into the speaker. The clip on that will not plug into my eclipse speakers. Is my only option to cut and splice ? Or does someone make a plug and play harness ? I mean its not a huge deal to cut and splice i would rather not cut a factory harness if i can avoid it.
Old Sep 29, 2008 | 03:17 PM
To my knowledge there isn't a plug and play harness, you can either
1) break apart OEM speakers to mod the adapters
2) cut off the OEM from car and either solder the correct adapter or just insert the bare wires
Old Sep 29, 2008 | 03:18 PM
kornerk12's Avatar
Old Sep 29, 2008 | 03:25 PM
JDM_DC4_Fanatic's Avatar
Default Re: (kornerk12)
You dont have to cut the connector off. You can strip some of the insulation and tap into the wire without cutting it. If you ever want to sell the car with the factory speakers, the plugs will still be there.
And, its proven the round speakers sound/perform better then oval speakers.
This, however is with the exception of subwoofers, which are more for movement of air then high frequency reproduction.
Silent9o8
Dec 19, 2005 09:07 AM
Alibi86
Sep 20, 2005 03:13 PM
Tupaz
Sep 1, 2004 02:55 PM
9accordboy5
Audio / Security / Video
Apr 23, 2003 07:11 PM
RoAnSa
Jan 1, 2003 12:27 AM
