Trans. problem
Old Sep 17, 2008 | 01:28 PM
Da Wasian's Avatar
Default Trans. problem
I have a honda civic 1992, 4 speed automatic. I have a transmission problem, when reaching second gear, I have to reduce speed for it to switch. Then I have to reduce to get to 3rd. That applys with 4th. What am I looking at here? I really don't know what the problem is, any ideas would be helpful.
Old Sep 17, 2008 | 04:03 PM
94EG8's Avatar
Seagull Management
Default Re: Trans. problem (Da Wasian)
did you check the fluid? is it burnt? If not i'd guess that the valve body is worn somewhat, either live with it or swap in another transmission. If the fluid looks bad, or smells burnt change it, use new honda fluid from the dealership.
Thagoldenb
Jan 4, 2011 08:12 PM
LLkoolskillet
Dec 24, 2010 02:40 PM
deesink
Sep 12, 2003 04:51 PM
Simple
Dec 12, 2002 05:59 PM
