My hatch doesn't have an a/c button can I connect the comp. to the fan switch
My hatch doesn't have the a/c button is there a way I can connect the a/c compressor power to the fan switch on the dash?
Thanks for all your help in advance.
Modified by lmgsr at 9:23 AM 9/17/2008
Quote:
yeah, this is where **** gets a little complicated! you definitely need to do something else like wiring in a relay to control the various things such as the fan the cools the condenser, you will need to also hook it up to a pressure switch to kick on and off the compressor so you do not over pressurize the system, then that switch has to also run to the compressor to turn it on. a simple switch will be fine to kick the system on but the relays and **** is where the headaches are. if you find a diagram for the a/c system it should be a breeze or find someone who knows a bit more about electrical systems.
I have all the relays and the pressure switch connected, I want to connect the wire from the pressure switch to the fan switch.
thnx
thnx
johnwohl
Dec 17, 2008 09:44 PM
