VTEC solenoid filter/gasket
Old Jul 25, 2002 | 07:18 PM
tinkerbell's Avatar
Default VTEC solenoid filter/gasket
is the JDM B16A VTEC solenoid seal/gasket/filter thing the same as a B16A2 or B16A3???
or any other series?
thanks,
t..
Old Jul 25, 2002 | 08:48 PM
JHill's Avatar
Default Re: VTEC solenoid filter/gasket (tinkerbell)
I am pretty sure they are all the same, I just put a brand new type R spool valve assembly onto my JDM B16A.
Old Jul 25, 2002 | 09:23 PM
Kamin's Avatar
Default Re: VTEC solenoid filter/gasket (JHill)
all the same.
Old Jul 25, 2002 | 09:36 PM
tinkerbell's Avatar
Default Re: VTEC solenoid filter/gasket (KAMiN)
cool, thanks guys
t..
Old Sep 11, 2004 | 01:56 PM
TurboTeG4's Avatar
So is it recommended to special order this thing when changed a solenoid to another motor.?
Old Sep 12, 2004 | 08:06 AM
mmuller's Avatar
Mad Scientist
Default Re: VTEC solenoid filter/gasket (TurboTeG4)
are you talking about an early b16?
1st gen vtec sol. are different than obd1+. and the gasket wont fit
Old Sep 12, 2004 | 09:48 AM
TurboTeG4's Avatar
Default Re: VTEC solenoid filter/gasket (mmuller)
94 gsr
Old Sep 26, 2004 | 06:53 PM
alexdog69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about an early b16?
1st gen vtec sol. are different than obd1+. and the gasket wont fit</TD></TR></TABLE>
what will fit ? ive been searching -- no one has an answer
Old Sep 26, 2004 | 09:13 PM
mmuller's Avatar
Mad Scientist
Default Re: VTEC solenoid filter/gasket (alexdog69)
what will fit? the right gasket.
I really dont know where to get a 1st gen gasket but...
here are some pics:
newer spool
1st gen spool:
no workie:
edit:the internals differ a little between the 2 also.spring and piston are interchangeable; the little round top piece is different between the 2
Old Sep 27, 2004 | 08:55 AM
EX-T's Avatar
If I'm not mistaken, a D series solenoid will also fit B series...
Old Sep 27, 2004 | 08:57 PM
PrettyLude's Avatar
will the d series one fit?
Old Oct 11, 2004 | 03:14 PM
alexdog69's Avatar
EF8/9 JDM B16A VTEC solenoid uses the 91 NSX P/N 15825-PR3-005
https://honda-tech.com/zeropost?cmd=tshow&id=996694
Jason Nucom
Nov 27, 2012 06:23 PM
wood 1
Aug 31, 2007 01:29 PM
Reelizmpro
Nov 28, 2004 10:43 PM
special edition
Feb 24, 2004 04:41 PM
madman13lm
Feb 21, 2003 06:13 AM
