Del Sol Won't Start
Old Sep 16, 2008 | 09:06 PM
JDMReverend's Avatar
Default Del Sol Won't Start
I'm guessing its not the starter because I was able to jump it with a screwdriver. What the vehicle is doing is when you turn the key nothing happens, no clicks, nothing. Checked the wire that goes into the starter and it was still in place but I removed it and reinserted it just in case, still nothing.
I'm thinking something came loose cause I was driving it all day today and then all of a sudden it wouldn't start. Where should I check?
Old Sep 16, 2008 | 09:10 PM
Nbboy7's Avatar
check the starter if the wire popped of the solenoid it won't do anything
Old Sep 16, 2008 | 09:14 PM
Thanks, but if you read my post it says I already did that.
Old Sep 16, 2008 | 09:44 PM
dtapia's Avatar
Default Re: (JDMReverend)
have you checked to see if you have a voltage signal to the starter wire while it is been cranked ?
Old Sep 17, 2008 | 02:25 PM
Del Sol SiR's Avatar
if its a manual tranny, is the sensor on the clutch pedal working?
Old Sep 17, 2008 | 04:41 PM
Got this fixed. Turned out to be the clutch pedal switch, I just looped the circuit so I can start it without pressing the clutch.
donnieb22000
12
Oct 22, 2016 09:13 AM
alex2423
Apr 2, 2014 01:25 PM
romomatic
Jun 24, 2013 12:57 PM
techsynthesis
Jan 18, 2009 06:10 PM
stockegsix
Oct 18, 2007 10:21 AM
