94 sedan clutch problem
Old Sep 16, 2008 | 07:55 PM
97civic94gsxr's Avatar
Default 94 sedan clutch problem
Hey guys i'm trying to help my friend get his civic back on the road. He was about to leave his house the other day and didnt have any pressure on the clutch, we both thought it was the cmc but we've replaced that and tried to bleed it but its not creating any pressure (pedal basically pops down to the floor if you move it down). Do you have to bench bleed a cmc like a bmc ? any help would be appreciated TIA
Old Sep 16, 2008 | 08:02 PM
94EG8's Avatar
Seagull Management
Default Re: 94 sedan clutch problem (97civic94gsxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys i'm trying to help my friend get his civic back on the road. He was about to leave his house the other day and didnt have any pressure on the clutch, we both thought it was the cmc but we've replaced that and tried to bleed it but its not creating any pressure (pedal basically pops down to the floor if you move it down). Do you have to bench bleed a cmc like a bmc ? any help would be appreciated TIA </TD></TR></TABLE>
Did you check the slave cylinder and the line? its pretty rare for the master cylinder to go bad on a honda, slave cylinders commonly fail though.
Old Sep 16, 2008 | 08:22 PM
Default Re: 94 sedan clutch problem (94EG8)
The cmc was leaking (onto the floorboard) thats why we originally thought thats what it was. We inspected the slave cylinder and it wasnt leaking.
Old Sep 16, 2008 | 08:27 PM
94EG8's Avatar
Seagull Management
how long did you bleed the clutch for? It takes a good 45 minutes or more and for almost all of that you wont feel anything.
Old Sep 16, 2008 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">how long did you bleed the clutch for? It takes a good 45 minutes or more and for almost all of that you wont feel anything.</TD></TR></TABLE> Well we attempted to bleed it like you would the brakes (pumping about 10 times then holding the pedal to the floor) i wasnt aware that you had to pump the clutch pedal so much. So when i'm trying to build up pressure should the clutch pedal feel as if theres nothing there at all ?
Old Sep 16, 2008 | 09:10 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">So when i'm trying to build up pressure should the clutch pedal feel as if theres nothing there at all ?</TD></TR></TABLE>
Yeah, pretty much. The first time I did one I was to a point where i was sure either my master cylinder or slave cylinder was bad, but no it just takes forever. The only other time I had to bleed a civic clutch it was exactly the same, took almost an hour. Just keep pumping, get an assistant while your at it cause your arm will probably get tired
Old Sep 16, 2008 | 10:03 PM
Thanks a lot man
Old Sep 18, 2008 | 02:50 PM
Alright we replaced the cmc a couple days ago and now the clutch has no grab to it as if the clutch is totally fried. The clutch felt fine before changing the cmc, is it possible there is air still in the line that is causing this ?
Edit - Yep that was the problem. Thanks anyway guys.
Modified by 97civic94gsxr at 6:31 PM 9/18/2008
Modified by 97civic94gsxr at 6:32 PM 9/18/2008
crazi3ge3
May 22, 2023 07:34 PM
ohsojdmdc
Jul 30, 2014 08:37 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 3, 2009 02:33 PM
yellowturbo
Feb 7, 2005 09:18 AM
AllMTRWH0R3
Aug 4, 2004 02:09 PM
