D16z6 with D15b7 IM.....problem. please help
Old Sep 16, 2008 | 04:34 PM
95-Accord-EX's Avatar
Default D16z6 with D15b7 IM.....problem. please help
I swapped to a D16z6, and just kept my D15b7 IM on there. I have CEL 14, Idea Air Control Valve. I replaced the unit, and reset the ECU and still had the code. I was told that the D16z6 had to have a "T" fitting for the coolant lines from the IAC, under the TB, and the block. I connected them like this... line from the head into the "T". Line from the IAC into the "T". Line from the TB into the "T". This didnt fix my problem tho.
I have a d16z6 IAC (I dont even know why i got this one, considering that I have a D15b7 IM) It should work the same tho right?
heres a pic of what im talking about:
http://i19.photobucket.com/alb...3.jpg
I think the line under the TB goes into the IAC. But idk where the line on the right goes to.
Thanks
Old Sep 16, 2008 | 04:40 PM
ILoveJDM89's Avatar
You would have better luck just buying a Z6 Manifold the b7 is Restrictive or Buy a Skunk 2 off ebay.
Old Sep 16, 2008 | 04:42 PM
94EG8's Avatar
Seagull Management
Default Re: D16z6 with D15b7 IM.....problem. please help (95-Accord-EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95-Accord-EX &raquo;</TD></TR><TR><TD CLASS="quote">I have a d16z6 IAC (I dont even know why i got this one, considering that I have a D15b7 IM) It should work the same tho right?</TD></TR></TABLE>
Yeah, its the same. Why are you using the D15B7 intake though? Its quite a bit more restrictive than the D16Z6 manifold.
Old Sep 16, 2008 | 05:20 PM
Default Re: D16z6 with D15b7 IM.....problem. please help (94EG8)
I got just the D16z6 block and head, i'm new to Civics. I had an Accord but i totaled it
I the metal tube on the right of the pic, goes up and joins the tube from the valve cover to the air intake. Does anyone know where the line goes from there? I see that it goes behind the TB and intake, but thats all i can find
Old Sep 16, 2008 | 05:27 PM
94EG8's Avatar
Seagull Management
it connects to a nipple on the metal water pipe that runs along the back of the block from the thermostat housing to the water pump.
Ben Parker
Sep 5, 2018 03:43 PM
Fourbangin4060
Jan 29, 2014 02:33 PM
helldriver88
Nov 17, 2009 12:54 PM
commotion
Jun 4, 2007 08:21 AM
