Please Help again!!! No spark?
I did the f22b1 motor swap everything is hooked up but a couple vacuum lines but my real problem now is that Im not getting any spark from my distributor and have no idea why... its plugged in the battery is good wires are in plugs are new and Im not getting power to the obd Im lost Again...
the light stays on and will till I get two O2 sensors welded in I got an OBD1 f22 in a OBD2 car all I got to do is cut and weld the sensors where they go thats cake but I dunno why Im not getting spark... Ill try the coil swap but I know the rotar is good and the plugs and wires are brand new also I have no power the the OBD port and dunno why same for the fuel gauge but all fuses and relays seem good
even though the o2 sensors are not it the check engine light will still cycle and once the engine is running the light will come back on informing you of a problem in the system.
so yes the light cycles or stays on ?
e-roc88
Nov 1, 2010 03:39 PM
s2kkk
20
Apr 15, 2004 11:12 AM
