Why does my engine light come on when dynoing???
Old Jul 25, 2002 | 06:28 PM
Lowez's Avatar
Default Why does my engine light come on when dynoing???
A few weeks ago my engine light came on while I was driving sometimes.. I took it to the dyno, and sure enough the light came on.. It was my o2 sensor on my B18C hybrid.. After the new o2 sensor the car ran mint... I gunned it a couple of times and no check engine light came on ever. Today I took the car to the dyno and the frigin engine light came on during the dyno run... Afterwards going home I reset the ecu, I reved the **** out of it and no engine light ever came on. Basically after the new o2 sensor has been installed Iv'e had no check engine light coming on ever. What on earth is going on here? An yone ever have this problem??? Any imput whould be appricated....
Old Jul 25, 2002 | 06:42 PM
minime's Avatar
Default Re: Why does my engine light come on when dynoing??? (Lowez)
was the cel o2 code or something else?
Old Jul 25, 2002 | 07:37 PM
builthatch's Avatar
MiG-21 superfan
do you take an o2 sensor out so you have a spot for the dyno's wideband? or do you just run the car for numbers and not tune?
Old Jul 26, 2002 | 09:14 AM
Lowez's Avatar
Default Re: Why does my engine light come on when dynoing??? (builthatch)
I never take the o2 sensor out when dynoing.. Why do U have to? When I first dynoed when I got the swap this problem didn't occur. The performance shop read the code and it was deffinetly the 02 sensor... Like I said the car never gives me a check engine light on the street ever....Any suggestions still????
Old Jul 26, 2002 | 09:34 AM
CHEETAH's Avatar
sometimes if ppl have a fuel controller, it tries to adjust beyond boudaries triggering c/e codes.
greg
Old Jul 26, 2002 | 10:47 AM
Lowez's Avatar
Default Re: Why does my engine light come on when dynoing??? (CHEETAH)
Thanks for the replys... I acually have a b&m fuel pressure regulater. Would I have to put the stock regulator back so that the engine light doesn't come on??? Or set the fuel pressure regulator to stock settings?????
92integraVTECgsr
Jan 21, 2008 07:48 AM
bliss22
Jan 16, 2008 01:03 PM
RedAndy007
Feb 13, 2006 01:28 PM
