How to measure milled head?
Old Sep 16, 2008 | 02:19 PM
cmerce's Avatar
Default How to measure milled head?
When doing the s2s2 head build on my car my dad took the casting to a friend who worked at a machine shop for a mill and hot tank. Now I'm swapping the head onto a different motor and I'd like to know how much was milled, the only problem is that my dad doesn't know how much was taken off at the machine shop. Is there a place on the head that I could take a micrometer measurement to figure it out?
Old Sep 16, 2008 | 03:02 PM
Fkned's Avatar
Default Re: How to measure milled head? (cmerce)
yes you can measure the distance from the valve cover rail to the deck and compare that to what stock is according to a helm's manual.
Old Apr 14, 2011 | 12:15 PM
Pssst!'s Avatar
Cylinder Head Height:
B18C1 - Standard (new): 141.95 - 142.05 mm (5.589 - 5.593 in)
B18B1 - Standard (new): 131.95 - 132.05 mm (5.195 - 5.199 in)
Old Apr 14, 2011 | 01:59 PM
C_Rock77's Avatar
YES. There's an indicator on the bottom surface of the head. It looks like a C. In stock configuration, I believe the depth is 1mm.
Creator
Nov 29, 2017 08:48 AM
josh green
Oct 24, 2010 07:52 PM
JDM_EK_JOE
Apr 20, 2006 06:33 AM
RagingAngel
Jan 21, 2003 10:16 AM
builthatch
May 7, 2002 04:19 PM
