help not starting
Old Sep 16, 2008 | 12:25 PM
1993gsrcivic's Avatar
Default help not starting
i just put my gsr in my car and i am getting fuel and spark and the timing is perfect
y wont this start?
gsr block, wiseco pistons, eagle rods, acl bearing, type r oil pump, gsr water pump,
gsr head, supertech valve train pro 1 cams w/ cam gears
skunk2 manifold tb str fuel rail 440 rc injectors
i took out the cams and put stock back in to c if it would run but still no luck
Old Sep 16, 2008 | 02:34 PM
civic95hbvtec's Avatar
Default Re: help not starting (1993gsrcivic)
Plug wires on correct ?
Valves to tight, maybe not closing all the way, so you got no compression ?
Do a compression test.
Old Sep 16, 2008 | 06:49 PM
Default Re: help not starting (civic95hbvtec)
1 = 0 comp
2 = 0 comp
3= 15 comp
4 = 60 comp
is there any way to seat the rings? i heard that i bit like a half cap of trans fluid may work
Old Sep 16, 2008 | 11:41 PM
Motor oil NOT tranny fluid.
Did you adjust the valves ?
Old Sep 17, 2008 | 05:22 AM
dtapia's Avatar
Default Re: (civic95hbvtec)
judging from the compression readings where the ring's installed the correct direction? wrong size ring ? head gasket installed up side down ? their is a lot of things that could have the results you got?
Old Sep 17, 2008 | 06:48 AM
Default Re: (dtapia)
i put the rings on the rings came with a diagram of where each gap was suposed to be and the block was bored .5 mm bigger the rings came with the pistons wiseco 11.8:1 81.5mm
Old Sep 17, 2008 | 12:21 PM
I just put together a built motor and it wouldent stay running because the valves wouldent close all the way.
check the valves seriously, you have had diffrent cams in and out try it !
Old Sep 17, 2008 | 07:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia &raquo;</TD></TR><TR><TD CLASS="quote">judging from the compression readings where the ring's installed the correct direction? wrong size ring ? head gasket installed up side down ? their is a lot of things that could have the results you got?</TD></TR></TABLE>
ok i took apart the motor and i re checked the ring gaps and the are perfect .01 thats what they are suposed to be
the head gasket was on the right way on the head gasket it says "UP" so that was correct
Old Sep 17, 2008 | 07:36 PM
Default Re: (1993gsrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic95hbvtec &raquo;</TD></TR><TR><TD CLASS="quote">I just put together a built motor and it wouldent stay running because the valves wouldent close all the way.
check the valves seriously, you have had diffrent cams in and out try it !</TD></TR></TABLE>
that is my next step to adjust my valves because the machine shop had my whole head aprt to do a port and polish and cleaning so my valves could be off
and i also heard with a high comp motor i need to run 93 gas to make is run also is this true?
Old Sep 18, 2008 | 11:33 AM
help
Old Sep 18, 2008 | 02:48 PM
Master23's Avatar
First of all does it crank? Even if the valve, ignition timing, piston ring gaps, etc is off it should still crank and start anyway. Recheck the wire harness and make sure you didn't miss plugging anything in.
Old Sep 18, 2008 | 03:51 PM
Default Re: (Master23)
yea the motor cranks but after i adjusted my valves it started so thanks 4 everyones help
Old Sep 25, 2008 | 01:46 PM
TOLD YOU... your welcome
And yes run premium fuels
boostedgsr1234
May 17, 2008 04:28 PM
Anti-Drama Queens
30
Jun 19, 2006 07:34 PM
xpsonic
Feb 14, 2006 11:18 AM
xpsonic
Feb 3, 2006 11:37 AM
robGSR
Nov 2, 2004 05:14 PM
