Coolant Hoses
Old Sep 16, 2008 | 11:32 AM
JScott3d's Avatar
Default Coolant Hoses
does anyone have the whole image
I need it to run my coolant lines. And out of all the ones that I have found online its by far the clearest.
Old Sep 16, 2008 | 11:58 AM
beige89civic's Avatar
* B A N N E D *
Default Re: Coolant Hoses (JScott3d)
Go to hondapartsunlimited.com and view parts explosions. It will at least give you an idea. What car and what motor?
Old Sep 16, 2008 | 12:16 PM
JScott3d's Avatar
91' B18a1
Old Sep 16, 2008 | 01:26 PM
Ldo's Avatar
Ldo
I'm trying to understand this myself. I'm doing a B18C into a CRX. The diagram looks very similar.
What's that square block at the lower right corner? Is that for the heater? Our EF has a heater hose coming out of the firewall, where does that go if using this diagram?
Go to Delray Acura website, look up parts for LS integra under Water Hoses, you'll see an exploded diagram.
Old Sep 17, 2008 | 11:36 AM
alscrx's Avatar
Default Re: Coolant Hoses (Ldo)
Guys its the same heater setup like with the d series. That little box is mounted with a bracket connects to the hose off the fire wall, and the other end gets the hose off the motor
Modified by alscrx at 3:41 PM 9/17/2008
Old Sep 17, 2008 | 12:45 PM
Ldo's Avatar
Ldo
Default Re: Coolant Hoses (alscrx)
Thanks for the pictures.
In your 2nd and 3rd picture, under the green plug, there's a small water connection that is not used. Did you cap it off or do you need to run it back to the thermo housing just like the first diagram (2 red circles)? My thermo housing doesn't have that extra inlet.
Old Sep 17, 2008 | 12:52 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ldo &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the pictures.
In your 2nd and 3rd picture, under the green plug, there's a small water connection that is not used. Did you cap it off or do you need to run it back to the thermo housing just like the first diagram (2 red circles)? My thermo housing doesn't have that extra inlet.</TD></TR></TABLE>
The b18a1 is an older motor and has that extra port which attaches to the metal tubing that go from your valve cover to your intake arm. You can eliminate that and run a straight hose. But since you have a b18c it must go somewhere else. Take some pics and i can help you out.
Old Sep 17, 2008 | 03:35 PM
Ldo's Avatar
Ldo
Thanks for the offer. I'll definitely take some pics.
I started a thread about this in the Integra forum but nobody was able to help me.
https://honda-tech.com/zerothread/2386709
I have some pics and diagram there. Everything looks like what's shown on your 3 pictures. I know that connection under the green plug should go to the metal tubing toward the intake back to the thermo housing. I just don't have another connection on the thermo housing for it or anywwhere else.
Old Sep 17, 2008 | 08:12 PM
sinepome's Avatar
i dont know the answer but i would like to know. this question is a humdinger.
Old Sep 18, 2008 | 05:34 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ldo &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the offer. I'll definitely take some pics.
I have some pics and diagram there. Everything looks like what's shown on your 3 pictures. I know that connection under the green plug should go to the metal tubing toward the intake back to the thermo housing. I just don't have another connection on the thermo housing for it or anywwhere else. </TD></TR></TABLE>
SO do you have the JDM housing with only a single nipple??
Or do you have the US housing?
Also, if you putting it in the crx....and you have the 2 main heater hoses connected like in the pics above and your sure you have no extra nipple on the head or manifold then cap it! The rex never had that on its thermo housing!
Modified by alscrx at 9:43 PM 9/18/2008
Old Sep 18, 2008 | 08:51 PM
Ldo's Avatar
Ldo
I have both thermo housings, but I'm using the JDM one. As you can see in both, C connector is missing.
Here's a picture of my current project, sorry for the terrible picture angle. Basically, "A" is looped back into the head at the intake manifold. "B" is connected to the heater hose at the firewall. "C" is supposed to go back to the upper radiator hose, but it's missing.
I think I'll just cap it off.
To the original poster, sorry if I have hijacked the thread.
Old Sep 22, 2008 | 07:23 PM
alscrx's Avatar
Just cap it off, Looks like there is nothing that can come out anyways. Looks as though that was closed from the factory~
Old Jan 12, 2010 | 01:48 AM
crxboy111's Avatar
so what u sayin is i can block the on comeing off the thermostat and the one that come off the tb ? ? ? please let me know cauase i so need help with this.My coolant keep comein out and its pissin me off =(
Old Feb 14, 2010 | 06:29 AM
stjohnsafc's Avatar
Surely its for the Heater Matrix Return?
As on the USDM main coolant neck/pipe (that runs from the water pump to the Thermostat) there are 3 nipples, Heater Outlet, Oil Cooler and IACV, where as on the JDM there are only 2, Oil Cooler and IACV
Basically instead of being on the Pipe its on the Thermo neck instead
mr.mengo
Jul 20, 2013 10:38 PM
cadwiese
Sep 29, 2012 12:07 PM
Jibin
Apr 24, 2010 07:42 PM
creepy116
Aug 5, 2007 08:51 PM
bow tie
Sep 12, 2006 09:04 AM
