New guy here looking for some input and info
Old Sep 16, 2008 | 04:45 AM
shitycivicsidekick's Avatar
Default New guy here looking for some input and info
The set up is
96 Gsr block bored to 81.5
Pauter rods
weisco 11:8-12:1 cp ratio pistons
Oem head gasket
arp rod bolts and head studs
fidanza i think it was the 11ish lb flywheel
ctr crank pully
ge block guard
00 gsr head
3angle valve job
sk2springs and retainers
msd wires
sk2 pro intake mani
hondata im gasket
aem cai
ngk racing 8's
noport and polish
stock cams
Ebay jvt header with 2.5 collector extended to the exhaust
apex ws2 exhaust
The car made 185.6 hp and 134 torqe im looking to push over 200 i recently purchased a b&m fpr and a blox 68mm tb and am looking into the sk2 pro stage 2 cam with pro cam gears and a walbro fuel pump. should i be looking into getting injectors as well and what size? also is there anything else i should be looking at. i was thinking of getting a better header as well .
Old Sep 17, 2008 | 07:36 PM
Default Re: New guy here looking for some input and info (shitycivicsidekick)
anyone???
Old Sep 17, 2008 | 07:52 PM
ruffrhyder's Avatar
A better quality header and those cams with proper tuning should gain you some good gains
Old Sep 17, 2008 | 08:57 PM
Mike@Highend Autosports's Avatar
Default Re: New guy here looking for some input and info (ruffrhyder)
Get some 310cc inj and a Highend tri-Y header
Old Sep 17, 2008 | 09:26 PM
Fat Chick Magnet's Avatar
and upgrade your cams also... like you listed.
Old Sep 17, 2008 | 10:29 PM
UncleD's Avatar
Default Re: New guy here looking for some input and info (Mike@Highend Autosports)
I'm assuming the car was tuned with engine management correct? So why the addition of a really shitty B&M fpr? Yeah - and do like everyone else does, buy a Ebay/Rage/WhoisDan/MF/Omni/High End/Blox "header."
Old Sep 19, 2008 | 07:11 PM
Default Re: New guy here looking for some input and info (clean rice)
Due to some theifs i just put the car back togeather and wanted to get it on the road again so i had to get it tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">A better quality header and those cams with proper tuning should gain you some good gains </TD></TR></TABLE>
my friend has hytech rep headers hes going to sell so i might pick them up and he has a similar setup and was told to get 440s but im thinking they are a bit big for the setup
\<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">and upgrade your cams also... like you listed.</TD></TR></TABLE>
im looking into it would the prostage 2 do it or should i go with a bigger cam like the pro stage 3 cam or what other options do i have ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming the car was tuned with engine management correct? So why the addition of a really shitty B&M fpr? Yeah - and do like everyone else does, buy a Ebay/Rage/WhoisDan/MF/Omni/High End/Blox "header."</TD></TR></TABLE>
yes it was tuned on hondata and i herd the b&m was pretty decent? with out the high price tag. and like i said i just wanted to get the car back on the road again drivable so i took the cheapest way out but i might get into a better header for sure.
Old Sep 23, 2008 | 06:23 PM
anyinfo from anyone would be great thanks looking to deff push over the 200 mark possibly more with the fuel upgrade cams and throttle body
Old Sep 23, 2008 | 07:01 PM
PyroProblem's Avatar
186whp is pretty good for stock port/stock cams...
Definately get some better cams, itll change how the whole engine breathes...
As far as injectors go, there is a calculator at http://www.rceng.com
Old Sep 23, 2008 | 10:41 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: (PyroProblem)
ONny your tuner will be able to tell you what size injectors you need by measuring the duty cycle on the dyno.. I would venture to guess 310s or 370s would work for that setup.
Cams are going to REALLY open up this setup. I have basically the exact same setup and even though you didn't post a dyno I'm willing to bet there is a huge hp jump at VTEC due to you being under-cammed.
Do NOT go with the pro 3.. that is WAY to big for this setup.. you are on the border between pro 1 and 2.. the 2 will probably be fine.
I'd leave the TB untill later, you can easily hit 200whp and more with a stock 60mm.
hytech replicas are ok for the money, you would be better off with a real header for this setup. FYI I have a VERY similar setup and my comptech header **** all over my hytech rep under 7500... as much as 10whp at some rpms.
Old Sep 24, 2008 | 03:46 AM
Default Re: (2LEM1)
wouldent a throttle body give you better responce over the 60mm and yeah im problably going to go with the pro 2 cams. and comptech headers are expensive lol i dont have that money yet but if i found a used set out here in ny it would be worth it probably
Old Sep 28, 2008 | 04:11 PM
Default Re: (shitycivicsidekick)
upp
Old Sep 29, 2008 | 08:52 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shitycivicsidekick &raquo;</TD></TR><TR><TD CLASS="quote">i recently purchased a b&m fpr and a blox 68mm tb and am looking into the sk2 pro stage 2 cam with pro cam gears
ECU tuning It will be tricky to tune that well with FPR.
Old Sep 29, 2008 | 01:27 PM
Default Re: New guy here looking for some input and info (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">ECU tuning It will be tricky to tune that well with FPR.</TD></TR></TABLE>
what do you mean it will be hard to tune with the fpr ? should i just leave a stock one on it ? or is it worth getting a better fpr if you could give me some pros and cons that would be great.
the prostage 2 should be good for mysetup im guessing? any other cams that would mabee give me more power ?
i have the throttlebody allready but havent installed it yet would it screw up my current tune if i did install it ? or should i put it on when i get the cams and everything else to get it retuned. ?
Novtec4u
30
Feb 26, 2009 04:28 PM
ns060
Nov 9, 2008 10:55 AM
Skunk2R
11
Oct 19, 2008 05:46 PM
jeffy
Mid-Atlantic (Sales)
Nov 9, 2007 04:16 PM
del_slow420
23
Oct 19, 2006 07:28 PM
