Classic Hondas All Pre-1988 Hondas.
87 crx si problems!!
Old Sep 15, 2008 | 06:36 PM
olskoolrex's Avatar
Default 87 crx si problems!!
wat up guys here are my issues i have an 87 crx si recently swapped a b series motor well now my brake light fuse and my starter fuse keep popping as soon as i connect the battery. I checked all the wiring to make sure nothings grounding out were its not suppose to. Does anyone have any ideas of what might be causing this problem?? any input very appreciated ive been dealing with this problem for a while
Also does anyone know how to lower the front of these cars ???
And does anyone know if any aftermarket traction control bars are available for this year crx???
Old Sep 15, 2008 | 07:28 PM
1grex's Avatar
There are shorts to ground in the starter and brake light circuits. You lower the front by loosening the torsion bar bolts a few turns each.
Old Sep 16, 2008 | 06:52 AM
cbstd's Avatar
Default Re: 87 crx si problems!! (olskoolrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olskoolrex &raquo;</TD></TR><TR><TD CLASS="quote"> And does anyone know if any aftermarket traction control bars are available for this year crx??? </TD></TR></TABLE>
Nothing (or close to noting) is available in the aftermarket for these old cars.
go over to http://www.redpepperracing.com, the best forum for these old cars.
Scott
Old Sep 16, 2008 | 06:56 AM
Ross 2.0's Avatar
In a Junkyard near you.
You obviously have a wiring issue. Are you using the stock fuse box and ignition switch?
Need to know how you did the swap before we can really help..
Old Sep 16, 2008 | 03:50 PM
olskoolrex's Avatar
yes im using the stock fuse box and ignition switch. My engine harness was done by hasport and Zdyne so everything was pretty much plug in besides the pinning of the ecu
iNDyCRX
Dec 11, 2007 11:41 AM
Exit Music
Dec 11, 2005 08:55 AM
baked_beanz
Aug 31, 2005 01:51 PM
89dxhunchback
Aug 28, 2005 11:42 AM
