mini me ?
Old Sep 15, 2008 | 05:58 PM
dirtygsr99's Avatar
Default mini me ?
ok i have a sohc zc in my hatch can u put a vtec head on it like a z6 that may sound newby but i really dont know anything about a zc. ive only seen that done to a6 and a few other motors on zc so any help or info thaxs
Old Sep 15, 2008 | 06:00 PM
sleepingciv's Avatar
Default Re: mini me ? (dirtygsr99)
yes you can
Old Sep 15, 2008 | 07:15 PM
dirtygsr99's Avatar
shor answer but it helps i guess all i need this the head the z6 headgasket and timing belt and a ecu and of course obd1 the car anything else well water pump and oil pump while im at it i think thats it if im missing anything chim in
Old Sep 15, 2008 | 07:25 PM
Default Re: (dirtygsr99)
use the y8 head gasket its a multi layer steel gasket, and yes the z6 timing belt
also oil change filter, water pump ect....
you dont have to run a obd1 ecu you can run the pm6 or whatever and run the vtec on a rpm activated switch
obd1 is nice for tuning though
also make sure ya take out the oil jet in between #2 #3 pistons if you dont vtec wont work
Modified by sleepingciv at 8:36 PM 9/15/2008
popndrop
13
Jan 27, 2009 08:31 PM
94VXLSHatchie
14
Aug 14, 2006 07:46 AM
SHG_Beans
20
Apr 4, 2006 12:41 PM
hb_guy
Jan 26, 2006 06:04 PM
