00 si b16a2 tranny with Type R ITR block what clutch kit to use ???
I have a 2000 civic SI trans with an integra 1.8L block. I know all b-series trans will bolt up but do I choose tranny side or engine side for the clutch and flywheel kit? Do I need b16 clutch or type R clutch?
Autozone for example has dif part numbers for the clutch kit and flywheel for 00 si and 01 itr...but online stores use the same part numbers. If they are all interchangable, then why was there a drilling noise when the clutch pedal was more than half way down and gears were grinding. It is brand new block with brand new clutch kit and flywheel with a good b16a2 tranny?
jmanjdm
Dec 9, 2014 04:40 PM
pinecone
Jun 22, 2006 05:27 PM
TRE_
16
Mar 9, 2003 09:25 AM
